assistants:overview_of_available_assistants
assistants:overview_of_available_assistants [2018-06-21 08:17] – [ESS Assistant] mvaderassistants:overview_of_available_assistants [2022-06-01 13:41] (current) – Fixed typo. fredhen
Line 28: Line 28:
 {{:assistants:self-consumption-hub-1-welcome.png?direct&150 }} {{:assistants:self-consumption-hub-1-policy.png?direct&150 }} {{:assistants:self-consumption-hub-1-welcome.png?direct&150 }} {{:assistants:self-consumption-hub-1-policy.png?direct&150 }}
-[[:assistants:self_consumption_hub-1|Self-consumption hub-1 Assistant]].+Note that Hub-1 is deprecated in favor of [[ess:start|ESS]].
-Deprecated in favor of [[ess:start|ESS]].+[[:assistants:self_consumption_hub-1|Hub-1 Assistant documentation]].
 +Hub-1 is only for hardware with new microprocessor (26 or 27).
-Only for hardware with new microprocessor (26 or 27). +[[assistants:hub1_and_hub2_notes|]]
 ==== DEPRECATED Self-consumption Hub-2 v3 - for ac-coupled systems ==== ==== DEPRECATED Self-consumption Hub-2 v3 - for ac-coupled systems ====
Line 43: Line 45:
 Only for hardware with new microprocessor (26 or 27). Only for hardware with new microprocessor (26 or 27).
 ==== DEPRECATED Self-consumption Hub-2 v2 - for ac-coupled systems ==== ==== DEPRECATED Self-consumption Hub-2 v2 - for ac-coupled systems ====
Line 50: Line 54:
 Take note of the [[:ac_coupling:start|factor 1.0 rule]]. Take note of the [[:ac_coupling:start|factor 1.0 rule]].
-Note that both Hub-2 Assistants are deprecated in favor of [[ess:start|ESS]].+Note that all Hub-2 Assistant versions have been deprecated in favor of [[ess:start|ESS]].
 ==== DEPRECATED Self-consumption Hub-4 ==== ==== DEPRECATED Self-consumption Hub-4 ====
Line 69: Line 74:
 ==== Generator start and stop ==== ==== Generator start and stop ====
-{{:assistants:c000c5d0534684c578209f4e3445bef0.png?direct&150 }}Automatically start and stop a generator based on battery state of charge and actual load of a system. Note that automatic genset start/stop functionality is also available on the Virtual switch tab, which is easier to configure and does not require uploading another type of firmware. See the PDF [[https://www.victronenergy.com/upload/documents/manual-VE.Bus-firmware-versions-explained-EN.pdf|VE.Bus firmware versions explained]] for more information about the different firmware types.+{{:assistants:c000c5d0534684c578209f4e3445bef0.png?direct&150 }}Automatically start and stop a generator based on battery state of charge and actual load of a system. Note that automatic genset start/stop functionality is also available on the Virtual switch tab in VEConfigure, which is easier to work with.
 +This is one of the available options to automatically start and stop a generator using Victron equipment. See the [[auto-generator-start-stop:start|]] document for an overview of all options. More general information about  using a generator in combination with Victron is available [[:multiplus_faq|here]].
 This Generator start and stop Assistant is also the one to use to [[:assistants:ignore_ac_input_using_the_generator_assistant|configure Ignore AC Input using Assistants]]. This Generator start and stop Assistant is also the one to use to [[:assistants:ignore_ac_input_using_the_generator_assistant|configure Ignore AC Input using Assistants]].
Line 75: Line 82:
 ==== AC Current sensor ==== ==== AC Current sensor ====
-{{:assistants:ac_current_sensor.png?direct&150 }}Reads PV Inverter current, using an AC Current sensor (CSE000100000), connected to a VE.Bus product. More information available in the [[https://www.victronenergy.com/upload/documents/Manual-AC-Current-sensor-EN.pdf|AC Current sensor manual]].+{{:assistants:ac_current_sensor.png?direct&150 }}Reads PV Inverter current, using an AC Current sensor (CSE000100000), connected to a VE.Bus product. More information available in the [[https://www.victronenergy.com/live/ac_current_sensor:start|AC Current sensor manual]].
 ==== Silence fan ==== ==== Silence fan ====
Line 97: Line 104:
 {{:assistants:85fa9bbfa1ab60f30e018fae30f2b3c2.png?direct&150 }}Used to wire an emergency stop button to a VE.Bus system. {{:assistants:85fa9bbfa1ab60f30e018fae30f2b3c2.png?direct&150 }}Used to wire an emergency stop button to a VE.Bus system.
-==== VE.Bus BMS support ====+==== DEPRECATED VE.Bus BMS support ====
-{{:assistants:d4c13a7dba68a0ac07ef946122785e57.png?direct&150 }}Required in combination with a [[https://www.victronenergy.com/batteries/lithium-battery-12,8v|VE.Bus BMS, used with our 12.8 V Lithium batteries]]. This Assistant communicates with the BMS and controls the Multi based on the BMS measurements.+{{:assistants:d4c13a7dba68a0ac07ef946122785e57.png?direct&150 }}
 +Deprecated: per VE.Bus firmware version 489, this Assistant is no longer required. When installing a system with VE.Bus BMS, our advice is to first update the firmware of the inverter, using VictronConnect, and thereafter do the configuration. No Assistant needed.
 +Required in combination with a [[https://www.victronenergy.com/batteries/lithium-battery-12,8v|VE.Bus BMS, used with our 12.8 V Lithium batteries]]. This Assistant communicates with the BMS and controls the Multi based on the BMS measurements.
 ==== Two-Signal BMS support (previously called Lynx Ion BMS support) ==== ==== Two-Signal BMS support (previously called Lynx Ion BMS support) ====
-{{:assistants:020b6a4a7ba5fc55edf4bdf7307dd0ed.png?direct&150 }}Required in combination with a [[https://www.victronenergy.com/batteries/lithium-battery-24v-180ah|Lynx Ion BMS, used with our 24 V 180 Ah Lithium system]]. This Assistant can also be used to control the Multi with a third party Lithium system including BMS. See our PDF [[https://www.victronenergy.com/upload/documents/Manual-Connecting-other-lithium-battery-systems-to-Multis-and-Quattros-EN.pdf|Connecting other lithium battery systems to Multis and Quattros]] for more information.+{{:assistants:020b6a4a7ba5fc55edf4bdf7307dd0ed.png?direct&150 }}Required in combination with a Lynx Ion BMS, used with our 24 V 180 Ah Lithium system. This Assistant can also be used to control the Multi with a third party Lithium system including BMS. See our PDF [[https://www.victronenergy.com/upload/documents/Manual-Connecting-other-lithium-battery-systems-to-Multis-and-Quattros-EN.pdf|Connecting other lithium battery systems to Multis and Quattros]] for more information.
Line 120: Line 131:
 {{:assistants:6e528aa50cd09a1740b2056370552464.png?direct&150 }} {{:assistants:6e528aa50cd09a1740b2056370552464.png?direct&150 }}
 +===== DISQUS =====
 ~~DISQUS~~ ~~DISQUS~~
assistants/overview_of_available_assistants.1529561830.txt.gz · Last modified: by mvader
