| Both sides previous revisionPrevious revisionNext revision | Previous revision |
| assistants:overview_of_available_assistants [2016-12-11 20:11] – [Self-consumption Hub-4] mvader | assistants:overview_of_available_assistants [2022-06-01 11:41] (current) – Fixed typo. fredhen |
| {{:assistants:ess-first-page.png?direct&150 }} | {{:assistants:ess-first-page.png?direct&150 }} |
| [[ess:start|]] | For Energy Storage Systems (ESS). The Assistant manages the prioritising of Solar Power. |
| Only for hardware with new microprocessor (26 or 27). | [[ess:start|Documentation]]. |
| ==== Self-consumption Hub-1 - for dc-coupled systems ==== | ==== PV Inverter support ==== |
| | {{:assistants:pvinvertersupport.png?direct&150 }} |
| | Use this Assistant in Off-grid systems that have AC-Coupled solar power: a grid-tie PV inverter connected to the AC out of a Multi or Quattro inverter/charger. |
| | [[:assistants:pv-inverter-support|Documentation]]. |
| | ==== DEPRECATED Self-consumption Hub-1 - for dc-coupled systems ==== |
| {{:assistants:self-consumption-hub-1-welcome.png?direct&150 }} {{:assistants:self-consumption-hub-1-policy.png?direct&150 }} | {{:assistants:self-consumption-hub-1-welcome.png?direct&150 }} {{:assistants:self-consumption-hub-1-policy.png?direct&150 }} |
| [[:assistants:self_consumption_hub-1|Self-consumption hub-1 Assistant]]. | Note that Hub-1 is deprecated in favor of [[ess:start|ESS]]. |
| | [[:assistants:self_consumption_hub-1|Hub-1 Assistant documentation]]. |
| | Hub-1 is only for hardware with new microprocessor (26 or 27). |
| Only for hardware with new microprocessor (26 or 27). | [[assistants:hub1_and_hub2_notes|]] |
| ==== Self-consumption Hub-2 v3 - for ac-coupled systems ==== | ==== DEPRECATED Self-consumption Hub-2 v3 - for ac-coupled systems ==== |
| {{:assistants:self-consumption-hub-2-v3-welcome.png?direct&150 }} {{:assistants:self-consumption-hub-2-v3-policy.png?direct&150 }} | {{:assistants:self-consumption-hub-2-v3-welcome.png?direct&150 }} {{:assistants:self-consumption-hub-2-v3-policy.png?direct&150 }} |
| Take note of the [[:ac_coupling:start|factor 1.0 rule]]. | Take note of the [[:ac_coupling:start|factor 1.0 rule]]. |
| See also our [[https://www.victronenergy.com/blog/2014/07/29/self-consumption-hub-2-v3-assistant-a-major-update/|blog post on the Self-consumption Hub-2 Assistant]]. | Deprecated in favor of [[ess:start|ESS]]. |
| Only for hardware with new microprocessor (26 or 27). | Only for hardware with new microprocessor (26 or 27). |
| ==== Self-consumption Hub-2 v2 - for ac-coupled systems ==== | [[assistants:hub1_and_hub2_notes|]] |
| | ==== DEPRECATED Self-consumption Hub-2 v2 - for ac-coupled systems ==== |
| Use only on hardware with old microprocessor (19 or 20). On newer systems, use the version 3 instead, see above. | Use only on hardware with old microprocessor (19 or 20). On newer systems, use the version 3 instead, see above. |
| ==== Self-consumption Hub-4 ==== | Note that all Hub-2 Assistant versions have been deprecated in favor of [[ess:start|ESS]]. |
| | ==== DEPRECATED Self-consumption Hub-4 ==== |
| {{:assistants:self-consumption-hub-4-welcome.png?direct&150 |}} | {{:assistants:self-consumption-hub-4-welcome.png?direct&150 |}} |
| ==== PV Inverter support ==== | |
| {{:assistants:pvinvertersupport.png?direct&150 }} | |
| Used in: | |
| * Off-grid PV installs | |
| * Systems using the Hub-4 Assistant with a PV Inverter connected to the output of the Multi or Quattro. Note that Hub-4 has been deprecated: use [[ess:start|ESS]] instead. And PV Inverter Support / frequency shifting is built into ESS: no need to add the PV Inverter Support Assistant as well. | |
| Take note of the [[:ac_coupling:start|factor 1.0 rule]]. | |
| ==== Generator start and stop ==== | ==== Generator start and stop ==== |
| {{:assistants:c000c5d0534684c578209f4e3445bef0.png?direct&150 }}Automatically start and stop a generator based on battery state of charge and actual load of a system. Note that automatic genset start/stop functionality is also available on the Virtual switch tab, which is easier to configure and does not require uploading another type of firmware. See the PDF [[https://www.victronenergy.com/upload/documents/manual-VE.Bus-firmware-versions-explained-EN.pdf|VE.Bus firmware versions explained]] for more information about the different firmware types. | {{:assistants:c000c5d0534684c578209f4e3445bef0.png?direct&150 }}Automatically start and stop a generator based on battery state of charge and actual load of a system. Note that automatic genset start/stop functionality is also available on the Virtual switch tab in VEConfigure, which is easier to work with. |
| | This is one of the available options to automatically start and stop a generator using Victron equipment. See the [[auto-generator-start-stop:start|]] document for an overview of all options. More general information about using a generator in combination with Victron is available [[:multiplus_faq|here]]. |
| This Generator start and stop Assistant is also the one to use to [[:assistants:ignore_ac_input_using_the_generator_assistant|configure Ignore AC Input using Assistants]]. | This Generator start and stop Assistant is also the one to use to [[:assistants:ignore_ac_input_using_the_generator_assistant|configure Ignore AC Input using Assistants]]. |
| ==== AC Current sensor ==== | ==== AC Current sensor ==== |
| {{:assistants:ac_current_sensor.png?direct&150 }}Reads PV Inverter current, using an AC Current sensor (CSE000100000), connected to a VE.Bus product. More information available in the [[https://www.victronenergy.com/upload/documents/Manual-AC-Current-sensor-EN.pdf|AC Current sensor manual]]. | {{:assistants:ac_current_sensor.png?direct&150 }}Reads PV Inverter current, using an AC Current sensor (CSE000100000), connected to a VE.Bus product. More information available in the [[https://www.victronenergy.com/live/ac_current_sensor:start|AC Current sensor manual]]. |
| ==== Silence fan ==== | ==== Silence fan ==== |
| {{:assistants:85fa9bbfa1ab60f30e018fae30f2b3c2.png?direct&150 }}Used to wire an emergency stop button to a VE.Bus system. | {{:assistants:85fa9bbfa1ab60f30e018fae30f2b3c2.png?direct&150 }}Used to wire an emergency stop button to a VE.Bus system. |
| ==== VE.Bus BMS support ==== | ==== DEPRECATED VE.Bus BMS support ==== |
| {{:assistants:d4c13a7dba68a0ac07ef946122785e57.png?direct&150 }}Required in combination with a [[https://www.victronenergy.com/batteries/lithium-battery-12,8v|VE.Bus BMS, used with our 12.8 V Lithium batteries]]. This Assistant communicates with the BMS and controls the Multi based on the BMS measurements. | {{:assistants:d4c13a7dba68a0ac07ef946122785e57.png?direct&150 }} |
| ==== Lynx Ion BMS support ==== | Deprecated: per VE.Bus firmware version 489, this Assistant is no longer required. When installing a system with VE.Bus BMS, our advice is to first update the firmware of the inverter, using VictronConnect, and thereafter do the configuration. No Assistant needed. |
| {{:assistants:020b6a4a7ba5fc55edf4bdf7307dd0ed.png?direct&150 }}Required in combination with a [[https://www.victronenergy.com/batteries/lithium-battery-24v-180ah|Lynx Ion BMS, used with our 24 V 180 Ah Lithium system]]. This Assistant can also be used to control the Multi with a third party Lithium system including BMS. See our PDF [[https://www.victronenergy.com/upload/documents/Manual-Connecting-other-lithium-battery-systems-to-Multis-and-Quattros-EN.pdf|Connecting other lithium battery systems to Multis and Quattros]] for more information. | Required in combination with a [[https://www.victronenergy.com/batteries/lithium-battery-12,8v|VE.Bus BMS, used with our 12.8 V Lithium batteries]]. This Assistant communicates with the BMS and controls the Multi based on the BMS measurements. |
| | ==== Two-Signal BMS support (previously called Lynx Ion BMS support) ==== |
| | {{:assistants:020b6a4a7ba5fc55edf4bdf7307dd0ed.png?direct&150 }}Required in combination with a Lynx Ion BMS, used with our 24 V 180 Ah Lithium system. This Assistant can also be used to control the Multi with a third party Lithium system including BMS. See our PDF [[https://www.victronenergy.com/upload/documents/Manual-Connecting-other-lithium-battery-systems-to-Multis-and-Quattros-EN.pdf|Connecting other lithium battery systems to Multis and Quattros]] for more information. |
| {{:assistants:6e528aa50cd09a1740b2056370552464.png?direct&150 }} | {{:assistants:6e528aa50cd09a1740b2056370552464.png?direct&150 }} |
| | ===== DISQUS ===== |
| ~~DISQUS~~ | ~~DISQUS~~ |
