Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision |
assistants:overview_of_available_assistants [2016-01-08 16:38] – ictbeheer | assistants:overview_of_available_assistants [2022-02-03 06:09] – [VE.Bus BMS support (Deprecated)] mvader |
Click on the thumbnails to see the full screenshot. | Click on the thumbnails to see the full screenshot. |
===== All-in-one Assistants ===== | |
==== Self-consumption Hub-1 - for dc-coupled systems==== | ===== 1. Assistants related to Solar ===== |
| Make sure to read [[https://www.victronenergy.com/blog/2016/09/05/configuring-solar-systems-with-quattros-and-multis/|Configuring solar systems with Quattros and Multis]] when configuring a solar system. |
{{:assistants:self-consumption-hub-1-welcome.png?direct&150 }} {{:assistants:self-consumption-hub-1-policy.png?direct&150 }} Only for hardware with new microprocessor (26 or 27). [[:assistants:self_consumption_hub-1|More information on the Self-consumption hub-1 Assistant]]. | ==== ESS Assistant ==== |
==== Self-consumption Hub-2 v3 - for ac-coupled systems ==== | {{:assistants:ess-first-page.png?direct&150 }} |
| For Energy Storage Systems (ESS). The Assistant manages the prioritising of Solar Power. |
| [[ess:start|Documentation]]. |
| ==== PV Inverter support ==== |
| {{:assistants:pvinvertersupport.png?direct&150 }} |
| Use this Assistant in Off-grid systems that have AC-Coupled solar power: a grid-tie PV inverter connected to the AC out of a Multi or Quattro inverter/charger. |
| [[:assistants:pv-inverter-support|Documentation]]. |
| ==== DEPRECATED Self-consumption Hub-1 - for dc-coupled systems ==== |
| {{:assistants:self-consumption-hub-1-welcome.png?direct&150 }} {{:assistants:self-consumption-hub-1-policy.png?direct&150 }} |
| Note that Hub-1 is deprecated in favor of [[ess:start|ESS]]. |
| [[:assistants:self_consumption_hub-1|Hub-1 Assistant documentation]]. |
| Hub-1 is only for hardware with new microprocessor (26 or 27). |
| [[assistants:hub1_and_hub2_notes|]] |
| ==== DEPRECATED Self-consumption Hub-2 v3 - for ac-coupled systems ==== |
{{:assistants:self-consumption-hub-2-v3-welcome.png?direct&150 }} {{:assistants:self-consumption-hub-2-v3-policy.png?direct&150 }} | {{:assistants:self-consumption-hub-2-v3-welcome.png?direct&150 }} {{:assistants:self-consumption-hub-2-v3-policy.png?direct&150 }} |
Only for hardware with new microprocessor (26 or 27). Take note of the [[:ac_coupling:start|factor 1.0 rule]]. See also our [[https://www.victronenergy.com/blog/2014/07/29/self-consumption-hub-2-v3-assistant-a-major-update/|blog post on the Self-consumption Hub-2 Assistant]]. | |
==== Self-consumption Hub-2 v2 - for ac-coupled systems==== | Take note of the [[:ac_coupling:start|factor 1.0 rule]]. |
Use only on hardware with old microprocessor (19 or 20). On newer systems, use the version 3 instead, see above. Take note of the [[:ac_coupling:start|factor 1.0 rule]]. | Deprecated in favor of [[ess:start|ESS]]. |
==== Self-consumption Hub-4 / grid parallel ==== | Only for hardware with new microprocessor (26 or 27). |
{{:assistants:self-consumption-hub-4-welcome.png?direct&150 |}}Only for hardware with new microprocessor (26 or 27).\\ See the also the [[:system_integration:hub4_grid_parallel|Hub4 / grid parallel manual]]. | |
===== Functional Assistants ===== | ==== DEPRECATED Self-consumption Hub-2 v2 - for ac-coupled systems ==== |
| Use only on hardware with old microprocessor (19 or 20). On newer systems, use the version 3 instead, see above. |
| Note that all Hub-2 Assistant versions have been deprecated in favor of [[ess:start|ESS]]. |
| ==== DEPRECATED Self-consumption Hub-4 ==== |
| {{:assistants:self-consumption-hub-4-welcome.png?direct&150 |}} |
| Do not use Hub-4 for new installs. It is deprecated in favor of [[ess:start|ESS]]. |
| [[:system_integration:hub4_grid_parallel|Hub-4 manual]]. |
| ===== 2. Functional Assistants ===== |
==== Generator start and stop ==== | ==== Generator start and stop ==== |
{{:assistants:c000c5d0534684c578209f4e3445bef0.png?direct&150 }}Automatically start and stop a generator based on battery state of charge and actual load of a system. Note that automatic genset start/stop functionality is also available on the Virtual switch tab, which is easier to configure and does not require uploading another type of firmware. See the PDF [[https://www.victronenergy.com/upload/documents/manual-VE.Bus-firmware-versions-explained-EN.pdf|VE.Bus firmware versions explained]] for more information about the different firmware types. | {{:assistants:c000c5d0534684c578209f4e3445bef0.png?direct&150 }}Automatically start and stop a generator based on battery state of charge and actual load of a system. Note that automatic genset start/stop functionality is also available on the Virtual switch tab in VEConfigure, which is easier to work with. |
| This is one of the available options to automatically start and stop a generator using Victron equipment. See the [[auto-generator-start-stop:start|]] document for an overview of all options. More general information about using a generator in combination with Victron is available [[:multiplus_faq|here]]. |
This Generator start and stop Assistant is also the one to use to [[:assistants:ignore_ac_input_using_the_generator_assistant|configure Ignore AC Input using Assistants]]. | This Generator start and stop Assistant is also the one to use to [[:assistants:ignore_ac_input_using_the_generator_assistant|configure Ignore AC Input using Assistants]]. |
==== AC Current sensor ==== | ==== AC Current sensor ==== |
{{:assistants:ac_current_sensor.png?direct&150 }}Reads PV Inverter current, using an AC Current sensor (CSE000100000), connected to a VE.Bus product. More information available in the [[https://www.victronenergy.com/upload/documents/Manual-AC-Current-sensor-EN.pdf|AC Current sensor manual]]. | {{:assistants:ac_current_sensor.png?direct&150 }}Reads PV Inverter current, using an AC Current sensor (CSE000100000), connected to a VE.Bus product. More information available in the [[https://www.victronenergy.com/live/ac_current_sensor:start|AC Current sensor manual]]. |
==== Silence fan ==== | ==== Silence fan ==== |
{{:assistants:85fa9bbfa1ab60f30e018fae30f2b3c2.png?direct&150 }}Used to wire an emergency stop button to a VE.Bus system. | {{:assistants:85fa9bbfa1ab60f30e018fae30f2b3c2.png?direct&150 }}Used to wire an emergency stop button to a VE.Bus system. |
==== VE.Bus BMS support ==== | ==== DELRECATED VE.Bus BMS support ==== |
{{:assistants:d4c13a7dba68a0ac07ef946122785e57.png?direct&150 }}Required in combination with a [[https://www.victronenergy.com/batteries/lithium-battery-12,8v|VE.Bus BMS, used with our 12.8 V Lithium batteries]]. This Assistant communicates with the BMS and controls the Multi based on the BMS measurements. | {{:assistants:d4c13a7dba68a0ac07ef946122785e57.png?direct&150 }} |
==== Lynx Ion BMS support ==== | Deprecated: per VE.Bus firmware version 489, this Assistant is no longer required. When installing a system with VE.Bus BMS, our advice is to first update the firmware of the inverter, using VictronConnect, and thereafter do the configuration. No Assistant needed. |
{{:assistants:020b6a4a7ba5fc55edf4bdf7307dd0ed.png?direct&150 }}Required in combination with a [[https://www.victronenergy.com/batteries/lithium-battery-24v-180ah|Lynx Ion BMS, used with our 24 V 180 Ah Lithium system]]. This Assistant can also be used to control the Multi with a third party Lithium system including BMS. See our PDF [[https://www.victronenergy.com/upload/documents/Manual-Connecting-other-lithium-battery-systems-to-Multis-and-Quattros-EN.pdf|Connecting other lithium battery systems to Multis and Quattros]] for more information. | Required in combination with a [[https://www.victronenergy.com/batteries/lithium-battery-12,8v|VE.Bus BMS, used with our 12.8 V Lithium batteries]]. This Assistant communicates with the BMS and controls the Multi based on the BMS measurements. |
==== PV Inverter support ==== | ==== Two-Signal BMS support (previously called Lynx Ion BMS support) ==== |
{{:assistants:pvinvertersupport.png?direct&150 }}Note that this is a deprecated Assistant, and only usefull in off-grid ac-coupled systems running on a Multi or Quattro with the old microprocessor (19 and 20). See these two configuration examples for more information: | {{:assistants:020b6a4a7ba5fc55edf4bdf7307dd0ed.png?direct&150 }}Required in combination with a Lynx Ion BMS, used with our 24 V 180 Ah Lithium system. This Assistant can also be used to control the Multi with a third party Lithium system including BMS. See our PDF [[https://www.victronenergy.com/upload/documents/Manual-Connecting-other-lithium-battery-systems-to-Multis-and-Quattros-EN.pdf|Connecting other lithium battery systems to Multis and Quattros]] for more information. |
* [[assistants:how_to_add_and_configure_an_assistant|How to add an Assistant from start to finish]] | |
* [[assistants:ignore_ac_input_using_the_generator_assistant|Ignore AC input using the Generator Assistant]] | |
And take note of the [[:ac_coupling:start|factor 1.0 rule]]. | |
===== Advanced Assistants ===== | ===== 3. Advanced Assistants ===== |
==== Programmable relay ==== | ==== Programmable relay ==== |
{{:assistants:6e528aa50cd09a1740b2056370552464.png?direct&150 }} | {{:assistants:6e528aa50cd09a1740b2056370552464.png?direct&150 }} |
| ===== DISQUS ===== |
~~DISQUS~~ | ~~DISQUS~~ |
