assistants:ignore_ac_input_using_the_generator_assistant
assistants:ignore_ac_input_using_the_generator_assistant [2014-08-03 13:24] – [Other options] mvader | assistants:ignore_ac_input_using_the_generator_assistant [2019-01-19 12:29] – [Other solutions] guy_stewart | ||
Line 5: | Line 5: | ||
Ignoring AC input will force a Multi or Quattro into inverter-mode on certain conditions, even though there is mains or generator power available. For example to force the system to run 100% on battery and solar power. | Ignoring AC input will force a Multi or Quattro into inverter-mode on certain conditions, even though there is mains or generator power available. For example to force the system to run 100% on battery and solar power. | ||
- | Ignoring the AC input was first introduced on the Virtual switch tab and can also be made with Assistants. | + | Ignoring the AC input was first introduced on the Virtual switch tab. It is much easier to use the Virtual switch to configure this, however if you must disable the Virtual switch due to another necessary assistants then it is possible to use an alternative way. |
- | + | ==== Other solutions | |
- | ==== Other options | + | Instead of using the Generator start/stop Assistant, |
- | Note that in many cases there are better options than what is explained here. For systems with recent hardware, which has the new-type microprocessor (the 7 digit firmware numbers starts with 26 or 27, instead of 19 or 20) use the Self-consumption Hub-2 v3 assistant. That is an all-in-one assistant takes away much of the complexity. | + | - Use the Virtual switch |
+ | - For systems with recent hardware, which has the new-type microprocessor (the 7 digit firmware numbers starts with 26 or 27, instead of 19 or 20) you could use the the [[https:// | ||
==== Making AC Ignore by using the Generator start/stop and the General flag assistant ==== | ==== Making AC Ignore by using the Generator start/stop and the General flag assistant ==== | ||
The most common (or only?!) system where below assistant configuration makes sense is an AC-coupled PV installation, | The most common (or only?!) system where below assistant configuration makes sense is an AC-coupled PV installation, |
assistants/ignore_ac_input_using_the_generator_assistant.txt · Last modified: 2019-01-22 10:16 by 127.0.0.1
