ac_coupling:start
ac_coupling:start [2020-05-29 16:54] – [2.1 Rule definition] guy_stewart | ac_coupling:start [2020-06-18 16:13] – [2.4 Should you look at the total PV array, or the PV inverter rating?] marmour | ||
Line 51: | Line 51: | ||
Line 60: | Line 60: | ||
And for an undersized PV array, where the total Wp of installed PV panels is less than the installed PV grid inverter, you use the Wp from the PV panels in your calculation. | And for an undersized PV array, where the total Wp of installed PV panels is less than the installed PV grid inverter, you use the Wp from the PV panels in your calculation. |
