ac_coupling:start
ac_coupling:start [2019-03-30 05:56] – [5 Software configuration] mvader | ac_coupling:start [2020-09-03 10:56] – removed accubank? guy_stewart | ||
Line 10: | Line 10: | ||
Line 22: | Line 24: | ||
Line 36: | Line 38: | ||
**The max PV power must be equal or less than the VA rating of the inverter/ | **The max PV power must be equal or less than the VA rating of the inverter/ | ||
- | In both grid-connected and off-grid systems with PV inverters installed on the output of a Multi, Inverter or Quattro, there is a maximum of PV power that can be installed. This limit is called the __factor 1.0 rule__: 3.000 VA Multi = 3.000 Wp installed solar power. So for a 8.000 VA Quattro the maximum is 8.000 Wp, for two paralleled 8000 VA Quattros the maximum is 16.000 Wp, etc. | + | In both grid-connected and off-grid systems with PV inverters installed on the output of a Multi, Inverter or Quattro, there is a maximum of PV power that can be installed. This limit is called the __factor 1.0 rule__: 3.000 VA Multi >= 3.000 Wp installed solar power. So for a 8.000 VA Quattro the maximum is 8.000 Wp, for two paralleled 8000 VA Quattros the maximum is 16.000 Wp, etc. |
Line 49: | Line 51: | ||
Line 58: | Line 60: | ||
Line 70: | Line 72: | ||
1 kWp installed PV power requires approximately 5kWh of battery: | 1 kWp installed PV power requires approximately 5kWh of battery: | ||
1,5 kWp installed PV power requires: | 1,5 kWp installed PV power requires: | ||
===== 4 Requirement of adding DC-Coupling - MPPT Solar Chargers ===== | ===== 4 Requirement of adding DC-Coupling - MPPT Solar Chargers ===== |
