ac_coupling:start
ac_coupling:start [2014-12-04 11:10] – [What is frequency shifting?] ellen | ac_coupling:start [2022-04-12 06:47] (current) – [1.1 What is AC-coupling?] bob | ||
====== AC-coupling and the Factor 1.0 rule ====== | ====== AC-coupling and the Factor 1.0 rule ====== | ||
- | Already familiar with the concepts of AC-coupling and regulating PV inverter output power by frequency shifting? Skip to [[: | + | ===== 1. Introduction to the AC-Coupling concept ===== |
- | ===== What is AC-coupling? | + | Already familiar with the concepts of AC-coupling and regulating PV inverter output power by frequency shifting? Skip to the requirements and limitations: |
+ | ==== 1.1 What is AC-coupling? | ||
Line 15: | Line 24: | ||
+ | * To read out SMA inverters, see [[ccgx: | ||
- | ===== What is frequency shifting? ===== | + | ==== 1.2 What is frequency shifting? ==== |
- | TODO: what is it? what is the purpose of it? how can a VE.Bus product configured to do it? | + | |
- | From most advised to least advised: | + | |
- | - With the Self-consumption Hub-2 v3 assistant | + | |
- | - PV Inverter support Assistant | + | |
- | - Use the Inverter period time settings on the Virtual switch tab.] | + | |
- | ===== Factor 1.0 rule: Max PV power in combination with frequency | + | Frequency shifting is used to regulate the output |
- | ==== Rule definition ==== | + | For how to configure, see chapter 4. |
- | In both grid-connected and off-grid systems with PV inverters installed on the output of a Multi, Inverter or Quattro, there is a maximum of PV power that can be installed. This limit is called the __factor 1.0 rule__: 3.000 VA Multi = 3.000 Wp installed solar power. So for a 8.000 VA Quattro the maximum is 8.000 Wp, for two paralleled 8000 VA Quattros the maximum is 16.000 Wp, etcetera. | + | |
- | ==== Example and background ==== | + | |
+ | ===== 2. The Factor 1.0 rule ===== | ||
+ | **The max PV power must be equal or less than the VA rating of the inverter/ | ||
+ | ==== 2.1 Rule definition ==== | ||
+ | In both grid-connected and off-grid systems with PV inverters installed on the output of a Multi, Inverter or Quattro, there is a maximum of PV power that can be installed. This limit is called the __factor 1.0 rule__: 3.000 VA Multi >= 3.000 Wp installed solar power. So for a 8.000 VA Quattro the maximum is 8.000 Wp, for two paralleled 8000 VA Quattros the maximum is 16.000 Wp, etc. | ||
+ | ==== 2.2 Example and background ==== | ||
To understand the background, consider the following situation: the PV inverter is at full power, supplying a big load. The Multi is in inverter mode. Then, suddenly and at once, this load is switched off. At that moment the PV inverter will continue operating at full power until the AC frequency has been increased. Increasing this frequency will take a very short time, but during that time all power will be directed into the batteries as there is no other place for it to go. This causes the following: | To understand the background, consider the following situation: the PV inverter is at full power, supplying a big load. The Multi is in inverter mode. Then, suddenly and at once, this load is switched off. At that moment the PV inverter will continue operating at full power until the AC frequency has been increased. Increasing this frequency will take a very short time, but during that time all power will be directed into the batteries as there is no other place for it to go. This causes the following: | ||
* When batteries are (nearly) full, the battery voltage will spike, possibly causing the Multi to switch off in DC over-voltage alarm. | * When batteries are (nearly) full, the battery voltage will spike, possibly causing the Multi to switch off in DC over-voltage alarm. | ||
Line 39: | Line 50: | ||
It is no problem to overpower the grid inverter by installing more solar panels. Some people do this to increase the generated solar power in winter time or rainy weather. Refer to the PV Inverter datasheet to maximum allowed installed PV power. Two times the inverter nameplate rating or even more is not uncommon! | It is no problem to overpower the grid inverter by installing more solar panels. Some people do this to increase the generated solar power in winter time or rainy weather. Refer to the PV Inverter datasheet to maximum allowed installed PV power. Two times the inverter nameplate rating or even more is not uncommon! | ||
- | ==== Charge current limit ==== | + | ==== 2.3 Charge current limit ==== |
Line 48: | Line 59: | ||
- In case the Multi is not connected to the grid, the 3000 Wp is more than the charger in a Multi 3000 VA can handle. The charger is around 2000 W. Therefore the grid inverter assistant will automatically increase the frequency to reduce the output of the grid inverter, to match maximum charge current. | - In case the Multi is not connected to the grid, the 3000 Wp is more than the charger in a Multi 3000 VA can handle. The charger is around 2000 W. Therefore the grid inverter assistant will automatically increase the frequency to reduce the output of the grid inverter, to match maximum charge current. | ||
- | ==== Should you look at the total PV array, or the PV inverter rating? ==== | + | ==== 2.4 Should you look at the total PV array, or the PV inverter rating? ==== |
+ | ===== 3. Minimum battery capacity ===== | ||
+ | Besides the relation between installed PV Power and the inverter/ | ||
+ | Note that, besides the minimum battery capacity, the mentioned sizes are often also the most economical battery size. In case used for self-consumption purposes that is. In case the goal is to increase autonomy, of course installing a large battery increases the system autonomy in case of a grid failure. | ||
+ | ==== 3.1 Lead batteries ==== | ||
+ | 1 kWp installed PV power requires approximately 5kWh of lead acid battery: | ||
+ | * 100 Ah at 48 Vdc | ||
+ | * 200 Ah at 24 Vdc | ||
+ | * 400 Ah at 12 Vdc | ||
+ | Each additional 1 kWp of AC PV will require an additional proportional 5 kWh increase in lead acid battery storage. | ||
+ | ==== 3.2 Lithium batteries ==== | ||
+ | 1,5 kWp installed AC PV power requires 4.8 kWh of battery storage: | ||
+ | Each additional 1.5 kWp of AC PV will require an additional proportional 4.8 kWh increase in battery storage. | ||
+ | ===== 4 Requirement of adding DC-Coupling - MPPT Solar Chargers ===== | ||
+ | Not required for Energy Storage Systems in Germany or other reliable grid situations. | ||
+ | Required for offgrid systems as well as backup systems that need to overcome extended grid failures. | ||
+ | Reason: recover from deadlock situation of AC-Coupling only situation. | ||
+ | There is no Factor 1.0 limit that applies for DC coupled PV through a Victron MPPT. Nor is there a specific minimum amount of battery storage capacity, though please follow battery manufacture specifications for maximum charge rates. A rule of thumb is C10 (10% of Ah capacity in A) for lead acid batteries, and C2 (50% of Ah capacity in A) for lithium batteries. | ||
+ | ===== 5 Software configuration ===== | ||
+ | Multis and Quattros with factory settings will not shift the AC output frequency to regulate charge current. When setting up an AC Coupled system, install either the [[ess: | ||
+ | The Inverter RS will automatically shift frequency without any additional configuration required when a surplus/ | ||
+ | Other options, __all deprecated__, | ||
+ | - Self-consumption Hub-2 v3 assistant | ||
+ | - Hub-4 Assistant in combination with the PV Inverter support Assistant | ||
+ | - Use the Inverter period time settings on the Virtual switch tab. | ||
+ | See [[https:// | ||
