Jul 30th - Aug 4th
http://www.sydneyboatshow.com.au
Exh. Centre, Darling Harbour, Sydney, Australia
2008 Dec 8th
Businesses like to communicate with the stream of potential customers walking past their premises on a daily basis. Marketing company Paves BV designed a Digital Pavement Billboard with dual LCD screens and mini speakers for just that purpose.To provide electricity to the mobile display, Victron Energy developed a convenient battery system. This avoids dangerous cabling across the pavement. Read full article
EasyPlus 12/1600/70The Phoenix EasyPlus is a multifunctional energy system consisting of a powerful sinewave inverter, a sophisticated battery charger, a high speed AC transfer switch and AC distribution in a single light weight and compact enclosure. The system has been designed for those who want to enjoy the comfort and freedom of a complete energy system without spending time on the installation of separate components and difficult technical procedures. |
Phoenix Multi ControlThis panel is intended both for Multi's and Quattro's. It allows PowerControl and PowerAssist current limit setting for two AC sources: a generator and shore-side current for example. Variable setting range (with the rotary knob): up to 16 Amps (VE.Bus Multi Control 16/200A panel) or up 30 Amps (VE.Bust Multi Control 30/200A panel). Fixed setting range (for both models): 200 Amps. The brightness of the LED's is automatically reduced during night time. |
Battery AlarmAn excessively high or low battery voltage is indicated by an audible and visual alarm, and a relay for remote signalling. |
RJ45 UTP CableAllows to connect Phoenix Inverter Control or VE Interface MK2b. 5M ASS030065000 10M ASS030065010 15M ASS030065020 |
Two AC inputs with integrated transfer switch. The Quattro can be connected to two independent AC sources, for example shore-side power and a generator, or two generators. The Quattro will automatically connect to the active source.
All Quattro- and several Multi inverter/chargers now have two AC outputs. In addition to the standard no-break output, an auxiliary output is available which disconnects the connected load during battery operation. It is, for example, the perfect solution for preventing an electric water heater from discharging your battery.
