Technical specifications
Smart BatteryProtect | SBP-65 | SBP-100 | SBP-220 | ||
Max. continuous load current | 65A | 100A | 220A | ||
Peak current | 250A | 600A | 600A | ||
Operating voltage range | 6 - 35 V | ||||
Current consumption | BLE On and when on: 1.4mA When off or low voltage shutdown: 0.9mA BLE Off and when on: 1.2mA When off or low voltage shutdown: 0.7mA | ||||
Alarm output delay | 12 seconds | ||||
Max. load on alarm output | 50mA - short circuit proof | ||||
Load disconnect delay | 90 seconds (immidiate if triggered by a BMS) | ||||
Load reconnect delay | 30 seconds | ||||
Default thresholds | Disengage: 10.5 V or 21 V Engage: 12 V or 24 V | ||||
Operating temperature range | Full load: -40 °C to +40 °C (up to 60% of nominal load at 50 °C) | ||||
Connection | M6 | M8 | M8 | ||
Mounting Torque | 5 Nm | 9 Nm | 9 Nm | ||
Weight | 0.2 kg 0.5 lbs | 0.5 kg 1.1 lbs | 0.8 kg 1.8 lbs | ||
Dimensions (hxwxd) | 40 x 48 x 106 mm | 59 x 42 x 115 mm | 62 x 123 x 120 mm | ||
1.6 x 1.9 x 4.2 inch | 2.4 x 1.7 x 4.6 inch | 2.5 x 4.9 x 4.8 inch |
