Smart BatteryProtect 12/24V
Error & Warning modes
There are 9 possible error modes and 2 warning codes, indicated by the 7-segment display and within the VictronConnect app when using a Bluetooth enabled smartphone or tablet:
  • E0 Calibration failure
  • E1 Short circuit
  • E2 Over temperature / P2 Over temperature warning
  • E3 Under voltage / P3 Under voltage warning
  • E4 Over voltage
  • E5 Configuration Failure
  • E6 Reference Voltage Failure
  • E7 BMS Lockout
  • E8 Reverse current
  • P2 Over temperature warning
  • P3 Under voltage warning
After 5 minutes the error is no longer displayed to reduce current consumption.
Please refer to the appendix chapter Error and Warning codes for more info on each error.
