SHS 200 MPPT
6. USER INTERFACE GUIDE
In this section:
6.1. Keypad layout
keypad layout
6.2. Menu map
menu map-1
Check the status of the USB ports.
menu-map-2
Check the status of the 12V port.
menu-map-3
WRENCH. Goes to the Service menu. It should only be used by technicians.
menu map-0
LOCK. Goes to the activation menu.
menu map checked
CHECK.
menu map-7
Shows the level of illumination of the panel. This is not an absolute value but mainly a relative indicator to help find the optimal position.
menu map-8
Shows an approximation of the state of charge of the battery (in %).
Displays the number of days left in the device before activation expires. If the device is fully activated, it is shown as such.
CANCEL. Key used to cancel and go back to last menu. Press three times the CANCEL key to reboot the unit.
