10. Technical Specifications
SHS 200 MPPT | ||
Battery voltage | 12Vdc | |
Nominal PV power | Up to 200Wp total (36 cells panels) | |
Maximum charge / discharge currents | 14A / 20A | |
Peak efficiency | 96% | |
Suitable battery capacity | Up to 160Ah | |
Compatible battery technologies | Sealed lead-acid, lithium. | |
Absorption / float voltages | 14.4V /13.75V (configurable) | |
Temperature compensation | Yes (automatic) | |
Automatic load disconnect | Yes (configurable low state of charge disconnect) | |
Operating temperatures | 0 to 40°C (derating from 35°C) | |
Humidity | 90%, non-condensing | |
Protections | Battery reverse polarity, battery overvoltage, battery undervoltage, battery overcurrent, load outputs overcurrent. | |
PAYGo | ||
Remote activation | Unlock tokens sent to end-user via SMS to activate the system | |
Compatible PAYGo platforms | PaygOps, Angaza, Paygee | |
Token technology | Free and secure open-source token system (OpenPAYGO) | |
ENCLOSURE | ||
PV terminals | Barrel model 4 x 5.5mmx2.1mm barrel connectors with an individual current limit of 5A | MC4 model A positive and a negative extension PV cable (1 meter - 14 AWg) terminated with MC4 connector. |
Battery cables | Included (14 AWG - 1m) / suitable for M6 battery terminals | |
USB outputs | 10 USB ports (type A) Voltage: 4.75V-5.25V Overall maximum of 10A across all ports Individual maximum of 1.5A per port Compliant with the USB Battery Charging 1.2 standard | |
Standard 12V DC outputs | Voltage: 10.5 to 15V (according to Lighting Global standard) Protection: software overcurrent protection and resettable fuse Port 1 (from top):
Port 2 and 3:
Port 4 and 5:
Color | Standard: black enclosure and blue keypad Customizable co-branding (minimum order quantity: 1000 units) | |
Dimensions (h x w x d) | 148 x 204 x 67 mm | |
Net weight | 0.39kg | |
Protection category | IP 41 |
