SHS 200 MPPT
10. SPECIFICATIONS
In this section:
SHS 200 MPPT
Battery voltage
12Vdc
Nominal PV power
Up to 200Wp total (36 cells panels)
Maximum charge / discharge currents
14A / 20A
Peak efficiency
96%
Suitable battery capacity
Up to 160Ah
Compatible battery technologies
Sealed lead-acid, lithium.
Absorption / float voltages
14.4V /13.75V (configurable)
Temperature compensation
Yes (automatic)
Automatic load disconnect
Yes (configurable low state of charge disconnect)
Operating temperatures
0 to 40°C (derating from 35°C)
Humidity
90%, non-condensing
Protections
Battery reverse polarity, battery overvoltage, battery undervoltage, battery overcurrent, load outputs overcurrent.
PAYGo
Remote activation
Unlock tokens sent to end-user via SMS to activate the system
Compatible PAYGo platforms
PaygOps, Angaza, Paygee
Token technology
Free and secure open-source token system (OpenPAYGO)
ENCLOSURE
PV terminals
Barrel model
4 x 5.5mmx2.1mm barrel connectors with an individual current limit of 5A
MC4 model
A positive and a negative extension PV cable (1 meter - 14 AWg) terminated with MC4 connector.
Battery cables
Included (14 AWG - 1m) / suitable for M6 battery terminals
USB outputs
10 USB ports (type A)
Voltage: 4.75V-5.25V
Overall maximum of 10A across all ports
Individual maximum of 1.5A per port
Compliant with the USB Battery Charging 1.2 standard
Standard 12V DC outputs
Voltage: 10.5 to 15V (according to Lighting Global standard) Protection: software overcurrent protection and resettable fuse
Port 1 and 2 (from bottom):
  • Current: Up to 3A
  • Connector: 5.5mm x 2.1mm barrel connector
Port 3 and 4:
  • Current: Up to 5A
Port 5:
  • Current: Up to 10A
  • Connector: 5.08mm pin space pluggable screw terminal
Color
Standard: black enclosure and blue keypad
Customizable co-branding (minimum order quantity: 1000 units)
Dimensions (h x w x d)
148 x 204 x 67 mm
Net weight
0.39kg
Protection category
IP 41
