6. Technical specifications
6.1. Phoenix Inverter Smart
Phoenix Inverter Smart | 12/1600 24/1600 48/1600 | 12/2000 24/2000 48/2000 | 12/3000 24/3000 48/3000 | 24/5000 48/5000 |
Parallel and 3-phase operation | No | |||
INVERTER | ||||
Input voltage range | 9.3 - 17V, 8.6 - 34V or 37.2 - 68V | |||
AC Output | 230Vac ±2%, 50Hz or 60Hz ± 0,1% (Non-linear load, crest factor 3:1) | |||
Continuous output power at 25ºC (1) | 1600VA | 2000VA | 3000VA | 5000VA |
Continuous output power at 25ºC | 1300W | 1600W | 2400W | 4000W |
Continious output power at 40ºC | 1200W | 1450W | 2200W | 3700W |
Continious output power at 65ºC | 800W | 1000W | 1700W | 2800W |
Peak power | 3000VA | 4000VA | 6000VA | 10000W |
Short-circuit output current | 13.9A | 17.4A | 26.0A | 43.5A |
Dynamic DC low shut down | Load dependant, configurable, see Dynamic cut off chapter | |||
Maximium efficiency (12/ 24 /48V) | 92 / 94 / 94% | 92 / 94 / 94% | 93 / 94 / 95% | 95 / 96% |
Zero load power 12 / 24 / 48 V | 8 / 9 /11W | 8 / 9 / 11W | 12 / 13 / 15W | 18 / 20W |
Zero load power in ECO mode | 0.6 / 1.3 / 2.1W | 0.6 / 1.3 / 2.1W | 1.5 / 1.9 / 2.8W | 2.2 / 3.2W |
GENERAL | ||||
Programmable relay | DC rating 4A@35V or 1A@60V, AC rating: 3A@230V | |||
Stop & start power ECO-mode | Adjustable via VictronConnect app | |||
Protection | Output short circuit, overload, low battery voltage, high battery voltage, over temperature, AC voltage on AC output, high DC ripple. | |||
Bluetooth wireless communication | For remote monitoring and system integration | |||
VE.Direct communication port | For remote monitoring and system integration | |||
Remote on/off connector | Yes | |||
Operating temperature range | -40 to +65ºC (fan assisted cooling) | |||
Humidity (non-condensing) | max 95%. | |||
Maximum altitude | 2000m | |||
Pollution degree classification | PDII | |||
Over voltage category | Mains: OVII | |||
ENCLOSURE | ||||
Material and colour | Steel (blue RAL 5012; and black RAL 9017) | |||
Protection category: | IP21 | |||
Battery connection terminals | M8 bolts | M8 bolts | 12 V/24 V: 2+2 M8 bolts 48 V: M8 bolts | 24 V: 2+2 M8 bolts 48 V: M8 bolts |
AC output connection terminals | Screw terminals | |||
Weight | 12kg | 13kg | 19kg | 29kg / 28kg |
Dimensions (hxwhd) | 485 x 219 x 125mm | 485 x 219 x 125mm | 533 x 285 x 150mm (12V) 485 x 285 x 150mm (24/28V) | 595 x 295 x 160mm (24V) 555 x 295 x 160mm (48V) |
STANDARDS | ||||
Safety | EN-IEC 60335-1 | |||
Emission Immunity | EN 55014-1 / EN 55014-2 / EN-IEC 61000-6-1 / EN-IEC 61000-6-2 / EN-IEC 61000-6-3 | |||
Automotive Directive | ECE R10-5 |
