7. Appendix
7.1. Connection overview
Connections 1600VA model
Connections 2000VA model
Connections 3000VA model
Connections 5000VA model
# | Connector | Terminal names |
A | AC output | L (phase), N (neutral), PE (earth) |
B | Battery | + (positve), - (negative) |
C | Alarm (programmable relay) | NO, COM, NC |
D | Remote | H, L |
E | VE.Direct | VE.Direct |
7.2. Installation information floating ground 1600VA and 2000VA models
Ground wire “G“ connects the output neutral to ground. It must be re-positioned to a "dummy" terminal if a floating output is required.
When a floating output is obtained, the current reading at no load can show an offset of around 100 - 50mA. Also beware that a GFCI (or RCCB) will not function properly.
7.3. Installation information floating ground 3000VA and 5000VA models
Ground wire “G“ connects the output neutral to ground. It must be re-positioned to a ‘dummy’ terminal if a floating output is required.
When a floating output is obtained, the current reading at no load can show an offset of around 100 - 150mA. Also beware that a GFCI (or RCCB) will not function properly.
7.4. Dimensions 1600VA and 2000VA model
7.5. Dimensions 3000VA model (12V)
7.6. Dimensions 3000VA model (24V, 48V)
7.7. Dimensions 5000VA model
