6. LED's
The LEDs will change its state to warn what the Orion Smart is doing at the moment. There are two LEDs, the blue LED is dedicated to Bluetooth functionality and the green LED to product state.
Status LED (Green LED)
LED off:
No input voltage
Remote shutdown;
Shutdown by the user;
Connector over-temperature protection
User defined under voltage lock-out
Engine off detected (when in Charger mode)
LED on:
Output active on Power supply mode
Charger in Float State (Battery charged);
LED Blinking at 1.25Hz:
Charger in Bulk or Absorption State (Battery is being charged);
BLE LED (Blue LED)
LED off:
No input voltage;
LED Blinking at 0.33 Hz:
Error – needs to be checked on VictronConnect;
LED Blinking at 1.25 Hz
Connected via Bluetooth
LED Blinking at 2.5 Hz:
Identify;
LED Blinking once every 5 seconds:
Charger off due to non-error conditions as:
Remote shutdown;
User defined under voltage lock-out;
Engine off detected (when in Charger mode);
LED on
All other conditions
