7. Technical specifications
MultiPlus-II 230V | 12/4k/180-32 | 48/4k5/55-32 | 48/6k5/100-50 | ||
PowerControl / PowerAssist | Yes | ||||
AC input voltage range | Input voltage range: 187 - 265VAC | ||||
AC input frequency range | Input frequency: 45 - 65Hz | ||||
Maximum feed-through current | 32A | 32A | 50A | ||
INVERTER | |||||
DC input voltage range | 9,5-17V | 38 - 60V | |||
AC output voltage | Output voltage: 230VAC ± 2% | ||||
AC output Frequency (1) | 50Hz ± 0.1% | ||||
Continuous output power at 25°C / 77°F | 3,4kW | 4kW | 6kW | ||
Continuous output power at 40°C / 104°F | 3,1kW | 3,7kW | 5,7kW | ||
Continuous output power at 65°C / 150°F | 2,6kW | 3kW | 4,6kW | ||
Time-limited power 1 (cold start) | 4kW/1h | 4,5kW/2h | 6,5kW/4h | ||
Time-limited power 2 (cold start) | 4,5k/2s | 6 kW/25min | 8kW/1h | ||
Maximum feed-in power | 3,4kW | 4kW | 6kW | ||
Peak power | 6kW/30s | 7kW/1min | 11kW/1min | ||
Maximum efficiency | 93% | 95% | 96% | ||
Zero-load power | 18W | 20W | 28W | ||
Zero-load power in AES mode | 11W | 13W | 18W | ||
Zero-load power in Search mode | 4W | 8W | 8W | ||
CHARGER | |||||
AC input voltage range | 187 - 265VAC | ||||
AC input frequency range | 45 - 65Hz | ||||
Charge voltage 'absorption' | 14,4V | 57,6V | |||
Charge voltage 'float' | 13,8V | 55,2V | |||
Storage mode | 13,2V | 52,8V | |||
Max. battery charge current at 25 °C (4) | 180A | 55A | 100A | ||
Max. battery charge current at 40 °C | 150A | 50A | 95A | ||
Battery temperature sensor | Yes | ||||
Compatible battery chemistries | Lithium, Lead-acid and more (3) | ||||
GENERAL | |||||
Auxiliary output | Yes (32A) | ||||
External AC current sensor (optional) | 50A or 100A | ||||
Programmable relay | Yes | ||||
Protection (2) | a - g | ||||
VE.Bus communication port | Three-phase and parallel operation, remote monitoring and system integration | ||||
General-purpose communication port | Yes, 2x | ||||
Operating temperature range | -40 to +65°C (-40 – 150°F), fan-assisted cooling | ||||
Maximum humidity | 95% (non-condensing) | ||||
Maximum altitude | 2000m | ||||
ENCLOSURE | |||||
Material & Colour | Steel, blue RAL 5012 | ||||
Pollution degree 2 | OVC3 | ||||
Protection category | IP 21 | ||||
Battery connections | Two positive M8 bolts and two negative M8 bolts | One positive M8 bolt and one negative M8 bolt | |||
AC connections | Screw terminals 13mm² (6 AWG) | ||||
Weight | 22kg | 22kg | 29kg | ||
Dimensions h x w x d | 576 x 276 x 164mm | 590 x 275 x 149mm | 644 x 320 x 150mm | ||
STANDARDS | |||||
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, EN-IEC 62109-1, EN-IEC 62109-2 | ||||
Emission / Immunity | EN 55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 | ||||
Uninterruptible power supply | IEC 62040 | ||||
Anti-islanding | IEC 62116 | ||||
