8. Technical Specifications
MultiPlus-II | 12/3000/120-50 | 24/3000/70-50 | 48/3000/35-50 | 48/5000/70-95 | ||
PowerControl & PowerAssist | Yes | |||||
Transfer switch | 50 A | 95 A | ||||
Maximum AC input current | 50 A | 95 A | ||||
INVERTER | ||||||
DC Input voltage range | 9.5 – 17 V | 19 - 33 V | 38 - 66 V | 38 - 66 V | ||
Output when in inverter mode | Output voltage: 120 VAC ± 2% Frequency: 60 Hz ± 0,1% (1) | |||||
Cont. output power at 25°C (3) | 3000 VA | 5000 VA | ||||
Cont. output power at 25°C | 2400 W | 4000 VA | ||||
Cont. output power at 40°C | 2200 W | 3700 VA | ||||
Cont. output power at 65°C | 1700 W | 3000 VA | ||||
Peak power | 5500 W | 9000 VA | ||||
Maximum efficiency | 93% | 94% | 95% | 96% | ||
Zero load power | 13 W | 13 W | 11 W | 15 W | ||
Zero load power in AES mode | 9 W | 9 W | 7 W | 10 W | ||
Zero load power in Search mode | 3 W | 3 W | 2 W | 3 W | ||
CHARGER | ||||||
AC Input | Single phase: 90-140 VAC 45 – 65 Hz | |||||
Charge voltage 'absorption' | 14.4 V | 28.8 V | 57.6 V | 57.6 V | ||
Charge voltage 'float' | 13.8 V | 27.6 V | 55.2 V | 55.2 V | ||
Storage mode | 13.2 V | 26.4 V | 52.8 V | 52.8V | ||
Maximum battery charge current (4) | 120 A | 70 A | 35 A | 70 A | ||
Battery temperature sensor | Yes | |||||
GENERAL | ||||||
Auxiliary output | Yes (32 A) | Yes (48A) | ||||
External AC current sensor (optional) | 100 A | |||||
Programmable relay (5) | Yes | |||||
Protection (2) | a – g | |||||
VE.Bus communication port | For parallel, split phase and three phase operation, remote monitoring and system integration | |||||
General purpose com. port (7) | Yes, 2x | |||||
Remote on-off | Yes | |||||
Operating temperature range | -40 to +65°C (-40 - 150°F) fan assisted cooling | -40 to +60°C (-40 - 140°F) fan assisted cooling | ||||
Humidity (non-condensing) | max 95% | |||||
ENCLOSURE | ||||||
Material & Colour | Steel, blue RAL 5012 | |||||
Protection category | IP21 | |||||
Battery-connection | M8 bolts | M8 bolts | M8 bolts | 2x M8 bolts | ||
120 VAC connection | Screw terminals 13 mm² (6 AWG) | 35 mm2 (2 AWG) | ||||
Weight | 19 kg (42 lb) | 32 kg (70 lb) | ||||
Dimensions (hxwxd) mm | 578 x 277 x 148 (22.7 x 10.9 x 5.8 inch) | 536 x 277 x 147 (21.1 x 10.9 x 5.8 inch) | 572 x 277 x 147 (22.5 x 10.9 x 5.8 inch) | 676 x 329 x 164 (26.6 x 13.0 x 6.5 inch) | ||
STANDARDS | ||||||
Listing | UL 458 | UL 458 | UL1741 | UL1741 pending | ||
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, CSA 22.2 107.1-16 | |||||
Emission, Immunity | EN 55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 | |||||
