Appendix A. Connection overview
A | Load connection. AC out1. Left to right: N (neutral), PE (earth/ground), L (phase) | |
B | Load connection. AC out2. Left to right: N (neutral), PE (earth/ground), L (phase) | |
C | AC input: Left to right: N (neutral), PE (earth/ground), L (phase) | |
D | Alarm contact: (left to right) NO, NC, COM. | |
E | Push button A – To perform a startup without assistants. | |
F | Primary ground connection M6 (PE). | |
G | M8 battery positive connection. | |
H | M8 battery minus connection. | |
I | switch: 1=On, 0=Off, ||=charger only | |
J | Connector for remote switch: Short to switch “on”. | |
K | 2x RJ45 VE-BUS connector for remote control and/or parallel / three-phase operation | |
L | External current sensor To connect the current sensor; remove the wire bridge between the INT and COM terminals, connect the red sensor wire to the EXT terminal and connect the white sensor wire to the COM terminal. | |
M | Terminal for: top to bottom:
