MultiPlus-II 12V/24V/48V 3kVA 120V
Appendix A. Connection overview
In this section:
A
Load connection. AC out1. Left to right: N (neutral), PE (earth/ground), L (phase)
B
Load connection. AC out2. Left to right: N (neutral), PE (earth/ground), L (phase)
C
AC input: Left to right: N (neutral), PE (earth/ground), L (phase)
D
Alarm contact: (left to right) NO, NC, COM.
Push button A – To perform a startup without assistants.
F
Primary ground connection M6 (PE).
G
M8 battery positive connection.
H
M8 battery minus connection.
I
switch: 1=On, 0=Off, ||=charger only
J
Connector for remote switch: Short to switch “on”.
K
2x RJ45 VE-BUS connector for remote control and/or parallel / three-phase operation
L
External current sensor
M
Terminal for: top to bottom:
  1. 12V 100mA
  2. Programmable contact K1 open collector 70V 100mA
  3. External ground relay +
  4. External ground relay –
  5. Aux input 1 +
  6. Aux input 1 –
  7. Aux input 2 +
  8. Aux input 2 –
  9. Temperature sense +
  10. Temperature sense –
  11. Battery voltage sense +
  12. Battery voltage sense -
