3. System design and BMS functionality
This chapter describes how the battery interacts with the BMS and how the BMS interacts with loads and chargers so that the battery is protected. This information is needed for system design and to be able to choose the most suitable BMS for that system.
3.1. The battery alarm signals and BMS actions
The battery monitors the cell voltages and the battery temperature and will send an alarm signal to the BMS in case one of these is outside the normal range.
The BMS protects the battery. It will turn loads and/or chargers off or generates a pre-alarm as soon as it receives an alarm signal from the battery.
These are the possible battery warnings and alarms and the corresponding BMS actions:
Battery alarm signal | BMS action |
Low cell voltage pre-alarm warning | The BMS generates a pre-alarm signal |
Low cell voltage alarm | The BMS turns loads off |
High cell voltage alarm | The BMS turns chargers off |
Low battery temperature alarm | The BMS turns chargers off |
High battery temperature alarm | The BMS turns chargers off |
The battery communicates these alarms to the BMS via its BMS cables.
The BMS receives an alarm signal from a battery cell
If the system contains multiple batteries, all battery BMS cables are connected in series (daisy chained). The first and the last BMS cable is connected to the BMS.
The BMS receives an alarm signal from a cell in a multiple battery setup
There are 3 ways the BMS can control loads and chargers:
By sending an electrical or a digital on/off signal to the charger or load.
By physically connecting or disconnecting a load or a charge source from the battery. Either directly or by using a BatteryProtect or Cyrix Li-ion relay.
The available BMS types for the lithium battery either rely on one or both of these technologies. The BMS types and their functionality are briefly described in the next chapters.
The BMS sends an on/off signal to a load or charger | The BMS connects or disconnects from a load or charger |
3.2. The BMS models
There is a choice of 6 different BMS models that can be used with the Lithium Battery Smart. Below overview explains the differences between them and their typical application.
BMS type | Voltage | Features | Typical application | |
SmallBMS | 12, 24 or 48V | Controls loads and chargers via on/off signals. Generates a pre-alarm signal. Note: The smallBMS was previously named miniBMS. | Small systems without inverter/chargers. | |
VE.Bus BMS | 12, 24 or 48V | Controls MultiPlus or Quattro via VE.Bus. Controls loads and chargers via on/off signals. Generates a pre-alarm signal. | systems with inverter/chargers. | |
Lynx Smart BMS 500 | 12, 24 or 48V | Controls loads and chargers via on/off signals. Can control inverter/chargers, solar chargers and select AC chargers via DVCC. Generates a pre-alarm signal. 500A contactor to disconnect system positive. Battery monitor. Bluetooth. Can connect to a GX device via VE.Can. Installed in system positive and negative. | Larger systems with digital integration or when a build-in safety relay is needed. | |
Smart BMS CL 12/100 | 12V | 100A dedicated alternator port. Controls loads and chargers via on/off signals. Generates a pre-alarm signal. Bluetooth. Installed in system positive. | Relatively small systems with an alternator. | |
![]() Smart BMS 12/200 | 12V | 200A dedicated alternator port. 200A dedicated DC system port. Controls loads and chargers via on/off signals. Generates a pre-alarm signal. Bluetooth. Installed in system positive. | Relatively small systems with an alternator and DC loads. | |
BMS 12/200 | 12V | 200A dedicated alternator port. 200A dedicated load and charger port. Installed in the system negative. Be aware that in many systems this is not ideal. | Relatively small systems with an alternator and DC loads but without inverter/charger. Note: This BMS is end of life, use a Smart BMS CL 12/100 or Smart BMS 12/200 instead. |
3.2.1. The Small BMS
The smallBMS is equipped with a “load disconnect”, a “charge disconnect” and a pre-alarm contact.
In the event of low cell voltage, the smallBMS will send a “load disconnect” signal to turn the load(s) off.
Prior to turning the load off, it will send a pre-alarm signal indicating imminent low cell voltage.
In the event of high cell voltage or low or high battery temperature, the smallBMS will send a “charge disconnect” signal to turn the charger(s) off.
For more information see the smallBMS product page.
![]() The smallBMS | The smallBMS controls loads and chargers via “load disconnect” and “charge disconnect” signals |
3.2.2. The VE.Bus BMS
The VE.Bus BMS is used in a system that also contains one or multiple Victron Energy inverter/chargers. The VE.Bus BMS directly communicates via the VE.Bus with the inverter/chargers. Just like the smallBMS, it also features a “load disconnect”, a “charge disconnect” and a "pre-alarm" contact.
In the event of low cell voltage, the VE.Bus BMS will send a “load disconnect” signal to turn off the load(s) and it will also turn the inverter of the inverter/charger off.
Prior to turning loads off, it will send a pre-alarm signal warning of imminent low cell voltage.
In the event of a high cell voltage or high/low battery temperature, the VE.Bus BMS will send a “charge disconnect” signal to turn the charger(s) off and it will also turn the charger of the inverter/charger off.
A mains detector and a short RJ45 UTP cable ship together with the VE.Bus BMS. These are needed for mains detection once the inverter/charger has been turned off by the BMS.
Note
The mains detector is not needed for the MultiPlus-II or Quattro-II series of inverter/chargers.
For more information see the VE.Bus BMS manual which can be found on the VE.Bus BMS product page.
VE.Bus BMS, V.Bus BMS mains detector and RJ45 UTP cable |
The VE.Bus BMS will turn loads and chargers off via “load disconnect”, and “charge disconnect” and controls the inverter/charger |
3.2.3. The Lynx Smart BMS
The Lynx smart BMS is used in medium to large systems that contain DC loads and AC loads via inverters or inverter/chargers, for example on yachts or in recreational vehicles. This BMS is equipped with a contactor that disconnects the DC system, a “load disconnect”, a “charge disconnect”, a "pre-alarm" contact and a battery monitor. In addition to this it can be connected to a GX device and control Victron Energy equipment via DVCC.
In the event of low cell voltage, the Lynx Smart BMS will send a “load disconnect” signal to turn the load(s) off.
Prior to turning a load off, it will send a pre-alarm signal indicating imminent low cell voltage.
In the event of high cell voltage or low/high battery temperature, the BMS will send a “charge disconnect” signal to turn the charger(s) off.
If the batteries are even further discharged (or overcharged), the contactor will open, effectively disconnecting the DC system to protect the batteries.
The Lynx smart BMS |
The Lynx Smart BMS will turn loads and chargers off via “load disconnect”, and “charge disconnect” signals and controls the inverter/charger via a GX device. Should the battery be discharged even further, the BMS will disconnect the battery from the DC system. |
3.2.4. The Smart BMS CL 12/100
The Smart BMS CL 12/100 is equipped with a “load disconnect”, a “charge disconnect” and a "pre-alarm" contact. The BMS also features a dedicated alternator port that will "current limit" the alternator current. It can be set for a variety of currents all the way up to 100A.
In the event of low cell voltage, the Smart BMS CL 12/100 will send a “load disconnect” signal to turn the load(s) off.
Prior to turning the load off it will send a pre-alarm signal indicating imminent low cell voltage.
In the event of high cell voltage or low/high battery temperature, the Smart BMS CL 12/100 will send a “charge disconnect” signal to turn the charger(s) off.
The alternator port controls and current limits the alternator.
For more information see the Smart BMS CL 12/100 product page.
![]() The Smart BMS CL 12/100 | The Smart BMS CL 12/100 will turn loads and chargers off via “load disconnect“ and “charge disconnect“ signals. It also controls and limits the alternator |
3.2.5. The Smart BMS 12/200
The Smart BMS 12/200 is equipped with a “load disconnect”, a “charge disconnect” and a "pre-alarm" contact. The BMS also features a dedicated alternator and system port. The alternator port will "current limit" the alternator current. It can be set for a variety of currents all the way up to 100A. The system port is used to connect the DC system and can be used for both charging and discharging the battery.
In the event of low cell voltage, the Smart BMS 12/200 will send a “load disconnect” signal to turn the load(s) off and will disconnect the load/charger port.
In the event of high cell voltage or low/high battery temperature, the Smart BMS 12/200 will send a “charge disconnect” signal to turn the charger(s) off.
![]() The Smart BMS 12/200 | The Smart BMS12/200 will disconnect loads and chargers or turn loads and chargers off via “load disconnect“ and “charge disconnect“ signals. It also controls and limits the alternator. |
3.3. The pre-alarm signal
The purpose of the pre-alarm is to warn the user that the BMS is about to turn off the loads because the battery is getting too empty. For example; you would want an early warning that loads are going to be turned off while manoeuvring your boat, or if lights are turned off when it is dark. We recommend connecting the pre-alarm to a clearly visible or audible alarm device. When the pre-alarm is raised the user can turn on a charger to prevent the DC system from shutting down.
Switching behaviour
In case of an imminent under voltage shutdown, the pre-alarm output of the BMS will switch on. In case the voltage continues to decrease, the loads are switched off (load disconnect) and at the same time the pre-alarm output will switch off again. In case the voltage rises again (operator has enabled a charger or has reduced the load) the pre-alarm output will switch off, once the lowest cell voltage has risen above 3.2V.
The BTV ensures a minimum delay of 30 seconds between enabling the pre-alarm and the load-disconnect. This delay is to allow the user a minimal amount of time to prevent the shutdown.
3.4. Charging from an alternator
Compared to lead acid batteries, lithium batteries have a very low internal resistance. They will accept a higher charge current than lead acid batteries. Because of this, special care must be taken when lithium batteries are charged from an alternator.
To safely connect an alternator, use one of these options:
Make sure that the alternator current rating is at least twice the battery capacity rating. For example; a 400A alternator can be safely connected to a 200Ah battery.
Use an alternator that is equipped with a alternator regulator with temperature control. This will prevent overheating of the alternator.
Use a current limiting device like a DC-DC charger or a DC-DC converter between the alternator and the starter battery.
Use a BMS with an alternator port with built-in current limiting, such as the Smart BMS CL 12/100 or the Smart BMS 12/200.
For more information on charging lithium batteries with an alternator, see the Alternator lithium charging blog and video.
Alternator charging
3.5. Battery monitoring
The common battery parameters, such as the battery voltage, battery temperature and cell voltages can be monitored via Bluetooth using the VictronConnect app. However, state of charge monitoring is not built into the battery. To monitor state of charge use the Lynx Smart BMS or add a battery monitor such as a BMV or a SmartShunt to the system.
If a battery monitor is used together with a lithium battery, adjust the following two settings:
Set the charge efficiency to 99%
Set the Peukert exponent to 1.05
For more information on battery monitors see the Battery monitor product page.
When a battery monitor is added to the system it matters how the battery monitor is powered. There are two options:
| ![]() The battery monitor power wire is conencted to the BMS |
| ![]() The battery monitor power wire is conencted to the battery |
