8. Technical specifications
Blue Smart IP65 Charger | 12V 4/5/7/10/15/25A | 24V 5/8/13A |
Input voltage | 230VAC | |
Efficiency | 94% | 95% |
Standby power consumption | 0.5W | |
Charge voltage 'absorption' | Normal: 14.4V High: 14.7V Li-ion: 14.2V | Normal: 28.8V High: 29.4V Li-ion: 28,4V |
Charge voltage 'float' | Normal: 13.8V High: 13.8V Li-ion: 13.5V | Normal: 27.6V High: 27.6V Li-ion: 27.0V |
Charge voltage 'storage' | Normal: 13.2V High: 13.2V Li-ion: 13.5V | Normal: 26.4V High: 26.4V Li-ion: 27.0V |
Output current, normal mode | 4 / 5 / 7 / 10 / 15 / 25A | 5 / 8 / 13A |
Output current, low current or night mode | 2 / 2 / 2 / 3 / 4 / 10A | 2 / 3 / 4A |
Temperature compensation (lead-acid batteries) | 16mV/°C | 32mV/°C |
Charge algorithm | 7-stage adaptive | |
Can be used as power supply | Yes | |
Back current drain | 0.7Ah/month (1mA) | |
Protection | Reverse polarity, Output short circuit, Over temperature | |
Operating temperature | -30 to +50°C (full rated output up to 30°C) | |
Humidity (non condensing) | Max 95% | |
Enclosure | ||
Battery-connection | 1.5 meter black and red cable | |
230V AC-connection | 1.5m cable with CE 7/16, CE 7/17, BS 1363 plug (UK) or AS/NZS 3112 plug | |
Protection category | IP65 (splash and dust proof) | |
Weight | 12V 25A & 24V 13A: 1.9kg Other models: 0.9kg | |
Dimensions (h x w x d) | 12V 4/5A: 45x81x182mm 12V 7A, 24V 5A: 47x95x190mm 12V 10/15A, 24V 8A: 60x105x190mm 12V 25A, 24V 13A: 75x140x240mm | |
Standards | ||
Safety | EN 60335-1, EN 60335-2-29 | |
Emission | EN 55014-1, EN 61000-6-3, EN 61000-3-2 | |
Immunity | EN 55014-2, EN 61000-6-1, EN 61000-6-2, EN 61000-3-3 |
