1. Safety instructions
Danger
CAUTION: CAREFULLY READ AND FOLLOW ALL SAFETY INSTRUCTIONS |
Ensure the area around the battery and charger is properly ventilated.
Do not cover or place any objects on top of the charger.
Do not place the charger on top of the battery.
Ensure that there are no sparks or ignition sources near the battery; batteries can emit explosive gasses while being charged.
Battery acid is corrosive; if battery acid comes into contact with skin immediately rinse with water.
Do not attempt to charge non-rechargeable or frozen batteries.
The charger must not be used by children or people who cannot read and understand the instruction manual, unless they are under strict supervision of a responsible person to ensure the charger is used safely.
Store and use the charger out of the reach of children.
The charger must be connected in the following order:
Connect the DC cable to the battery terminal that is not connected to the chassis
Connect the remaining DC cable to the chassis, away from the battery and any fuel lines/sources
Connect the AC power cable to a mains power outlet
After charging, the charger must the disconnected in the following order (reverse of the connection order):
Disconnect the AC power cable from the mains power outlet
Disconnect the DC cable that is connected to the chassis
Disconnect the DC cable connected to the battery terminal
Connection to the mains supply must be in accordance with local electrical regulations. In case the AC power cable is damaged, contact the manufacturer or a service agent.
