vrm_portal:vrm_juice_php_example
VRM Juice PHP Example
For more info about VRM Juice, see VRM JSON Juice API notes (DEPRECATED!)
Many thanks to Steven from http://lackancottage.co.uk/blog/, who wrote this code for his blog and providing it to us.
<?php
$url = 'https://juice.victronenergy.com/';
$username="YOUR VRM USERNAME";
$password="YOUR VRM PASSWORD";
$version="200.i";
$verification_token="1";
$instance="0";
$fields = array(
'username' => urlencode($username),
'password' => urlencode($password),
'version' => urlencode($version),
'verification_token' => urlencode($verification_token),
foreach($fields as $key=>$value)
$fields_string .= $key.'='.$value.'&';
rtrim($fields_string, '&');
$ch = curl_init();
curl_setopt($ch,CURLOPT_URL, $url."user/login");
curl_setopt($ch,CURLOPT_POST, count($fields));
curl_setopt($ch,CURLOPT_POSTFIELDS, $fields_string);
curl_setopt($ch,CURLOPT_RETURNTRANSFER, 1);
$result = curl_exec($ch);
$result=json_decode($result);
$sessionid=$result->data->user->sessionid;
$fields = array(
'sessionid' => urlencode($sessionid),
$ch = curl_init();
curl_setopt($ch,CURLOPT_URL, $url."sites/get");
$result = json_decode(curl_exec($ch));
if($result->status->code==200){
$i=0;
$str="";
$ajax_values=array();
foreach($result->data->sites as $site){
$i++;
$fields = array(
'siteid' => urlencode($site->idSite),
#ADD THE ATTRIBUTES YOU NEED TO RETURN HERE
'attributes'=> '[113, 131, 144, 143 ]',
'instance' => urlencode($instance),
$ch = curl_init();
curl_setopt($ch,CURLOPT_URL, $url."sites/attributes");
$attributes = json_decode(curl_exec($ch));
if($attributes->status->code==200){
$attributes=$attributes->data->attributes;
else{
$str.="Error in API Call. Try again<br /><h3>Error Description:</h3><p>".$attributes->status->message."</p>";
$ajax_values[$i-1]=array(
"site_id"=>$site->idSite,
"site_name"=>$site->name,
"attributes"=>array()
$str.='<div class="title" id="site_'.$site->siteId.'">'.$site->name.'</div>';
if(isset($attributes) && is_array($attributes)){
foreach($attributes as $attribute){
$str.='<div class="row" id="site_'.$site->idSite.'">';
$value="value".ucfirst($attribute->dataType);
switch($attribute->idDataAttribute){
case 131:
$str.="<div class='consumption'><div id='customlabel'>Consumption</div><div id='value'>We are using <span id='attribute_".$attribute->idDataAttribute."'>".round($attribute->$value, 2)."</span> W</div></div>";
$ajax_values[$i-1]["attributes"][]=array($attribute->idDataAttribute,round($attribute->$value, 2));
break;
case 113:
$str.="<div class='yield'><div id='customlabel'>Solar Yield:</div><div id='value'>Generating <span id='attribute_".$attribute->idDataAttribute."'>".round($attribute->$value, 1)."</span> W</div></div>";
$ajax_values[$i-1]["attributes"][]=array($attribute->idDataAttribute,round($attribute->$value, 1));
break;
case 143:
$str.="<div class='voltage'><div id='customlabel'>Battery:</div><div id='value'>Voltage <span id='attribute_".$attribute->idDataAttribute."'>".$attribute->$value."</span> V</div></div>";
$ajax_values[$i-1]["attributes"][]=array($attribute->idDataAttribute,$attribute->$value);
break;
case 144:
$str.="<div class='soc".($attribute->$value<=25?"1":($attribute->$value>25 && $attribute->$value<=50)?"2":($attribute->$value>50 && $attribute->$value<=75)?"3":"4")."'><div id='customlabel'>Battery:</div><div id='value'>SOC <span id='attribute_".$attribute->idDataAttribute."'>".$attribute->$value."</span>%</div></div>";
break;
$str.='</div>';
else{
$str.='<div class="row"> </div>';
$ajax_values[1]=$ajax_values[0];
if(!isset($_GET["ajax"])){
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.11.1/jquery.min.js"></script>
<script>
$(window).load(function(){
setInterval(function(){
$(".status_msg").show();
$.get("<?php echo $_SERVER['PHP_SELF']?>", {ajax: 1}, function(data){
data=data.split("##JSON##");
if(data[1]){
data = JSON.parse(data[1]);
for($i=0; $i<data.length; $i++){
for($j=0; $j<data[$i].attributes.length; $j++){
$("#site_"+data[$i].site_id+" #attribute_"+data[$i].attributes[$j][0]).html(data[$i].attributes[$j][1]);
$(".status_msg").hide();
}, 10000); // change this value to whatever interval you need for update
</script>
<style>
.status_msg{ display:none;}
.list{
border-collapse: collapse;
font-size: 11px;
margin: 0 auto;
width: 1000px;
.list .th, .list .td {
border: 1px solid #333;
padding: 5px; vertical-align:top;
.list .th {
background: none repeat scroll 0 0 #333;
border: 1px solid #fff;
color: #fff;
.list .tr.odd {
background: none repeat scroll 0 0 #ccc;
.list .tr.even {
background: none repeat scroll 0 0 #ff1;
.title { font-family: arial, sans-serif; font-size: 15px; font-weight:bold: }
.row {display: block; width: 300px;padding:10px;padding-left: 80px; margin:5px; border: 1px solid #666; }
#customlabel { font-family: arial, sans-serif; font-size: 13px; font-weight:normal; display:block;}
#value { font-family: arial, sans-serif; font-size: 13px; font-weight:normal; display:block;}
#consumption {background-image url('images/thumb_kwh_metre.png'); background-repeat:no-repeat; background-position: left, middle; }
#yield {background-image url('images/thumb_weather_00.png'); background-repeat:no-repeat; background-position: left, middle; }
#voltage {background-image url('images/thumb_lightning.png'); background-repeat:no-repeat; background-position: left, middle; }
#soc {background-image url('images/thumb_battery_4.png'); background-repeat:no-repeat; background-position: left, middle; }
</style>
<div class="list">
<?php echo $str;?>
<div class="status_msg">Updating...</div>
</div>
<p>
<?php
else
echo "##JSON##".json_encode($ajax_values)."##JSON##";
else
echo "Error in API Call. Try again<br /><h3>Error Description:</h3><p>".$result->status->message."</p>";
curl_close($ch);
<br />
<strong>Sample Values for Attribute ID's.</strong><br /> #description=Battery Power (System)
#Attribute ID 243 Value(valueFloat): -141.54%F%.0F W
<br /> #description=Grid L1
#Attribute ID 134 Value(valueFloat): 0%.0F%.0F W <br />
#description=AC Consumption L1
#Attribute ID 131 Value(valueFloat): 116%.0F%.0F W <br />
#description=Solar charger serial number
#Attribute ID 118 Value(valueString): HQ143299WX7%s%s
<br />
#description=PV - DC-coupled
#Attribute ID 113 Value(valueFloat): 0%.0F%.0F W <br />
#description=Battery watts
#Attribute ID 107 Value(valueFloat): 0%.0F%.0F W <br />
#description=Solarcharger model
#Attribute ID 106 Value(valueString): 108%s%s <br />
#description=Battery to consumers
#Attribute ID 105 Value(valueFloat): 0.0599995%.2F%.2F kWh<br />
#description=Error code
#Attribute ID 98 Value(valueEnum): 0%s%s <br /> #description=Maximum charge power yesterday
#Attribute ID 97 Value(valueFloat): 1118%d%d <br />
#description=Yield yesterday
#Attribute ID 96 Value(valueFloat): 1.83%.2F%.2F
<br /> #description=Maximum charge power today
#Attribute ID 95 Value(valueFloat): 157%d%d
<br /> #description=Yield today
#Attribute ID 94 Value(valueFloat): 0.4%.2F%.2F
<br /> #description=High batt. voltage alarm
#Attribute ID 93 Value(valueEnum): 0%s%s
<br /> #description=Low batt. voltage alarm
#Attribute ID 92 Value(valueEnum): 0%s%s
<br /> #description=Battery Voltage (System)
#Attribute ID 143 Value(valueFloat): 23.59%.2F%.2F V
<br /> #description=Battery State of Charge (System)
#Attribute ID 144 Value(valueFloat): 94%.1F%.1F %%
<br /> #description=Battery Consumed Amphours (System)
#Attribute ID 145 Value(valueFloat): -20.7%.2F%.2F Ah
<br /> #description=VE.Bus hidden SOC
#Attribute ID 240 Value(valueFloat): 84.5%.1F%.1F %%
<br /> #description=Network traffic rx
#Attribute ID 239 Value(valueFloat): 89506%d%d B
<br /> #description=Network traffic tx
#Attribute ID 238 Value(valueFloat): 8997%d%d B
<br /> #description=Boot type
#Attribute ID 237 Value(valueEnum): 1%s%s <br />
#description=log time offset
#Attribute ID 216 Value(valueFloat): 119%s%s s
<br /> #description=Battery state
#Attribute ID 215 Value(valueEnum): 2%s%s
<br /> #description=Remote support
#Attribute ID 154 Value(valueEnum): 0%s%s
<br /> #description=VE.Bus charge current (System)
#Attribute ID 153 Value(valueFloat): -5.7%.1F%.1F A
<br /> #description=Update to
#Attribute ID 151 Value(valueEnum): 0%d%d
<br /> #description=Auto update
#Attribute ID 150 Value(valueEnum): 1%d%d
<br /> #description=Local ip address
#Attribute ID 149 Value(valueString): 192.168.2.2%s%s
#<br /> #description=Remote ip address
#Attribute ID 148 Value(valueString): 88.145.32.15%s%s
<br /> #description=Battery Current (System)
#Attribute ID 147 Value(valueFloat): -6%.2F%.2F A
<br /> #description=Battery Time to Go (System)
#Attribute ID 146 Value(valueFloat): 23.5%.2F%.2F h
<br /> #description=Relay on the charger
#Attribute ID 90 Value(valueEnum): 0%s%s
<br /> #description=PV current
#Attribute ID 87 Value(valueFloat): 0%.1F%.1F
<br /> #description=PV voltage
#Attribute ID 86 Value(valueFloat): 10.98%.2F%.2F
<br /> #description=Active input current limit
#Attribute ID 27 Value(valueFloat): 3.1%.2F%.2F A
<br /> #description=Output frequency
#Attribute ID 26 Value(valueFloat): 49.8982%.2F%.2F Hz
<br /> #description=Output current phase 1
#Attribute ID 23 Value(valueFloat): 0.64%.1F%.1F A
<br /> #description=Output voltage phase 1
#Attribute ID 20 Value(valueFloat): 245.02%.1F%.1F VAC
<br /> #description=Input power 1
#Attribute ID 17 Value(valueFloat): 0%.0F%.0F VA
<br /> #description=Input frequency 1
#Attribute ID 14 Value(valueFloat): 50.1026%.2F%.2F Hz
<br /> #description=Input current phase 1
#Attribute ID 11 Value(valueFloat): 0%.1F%.1F A
<br /> #description=Input voltage phase 1
#Attribute ID 8 Value(valueFloat): 247.06%.1F%.1F VAC
<br /> #description=VE.Bus device version
#Attribute ID 7 Value(valueString): 2610304%s%s
<br /> #description=mk2 version
#Attribute ID 6 Value(valueString): 1130133%s%s
<br /> #description=Longitude
#Attribute ID 5 Value(valueFloat): -6.08909%.5F%.5F LNG
<br /> #description=Latitude
#Attribute ID 4 Value(valueFloat): 54.2621%.5F%.5F LAT
<br /> #description=gatewayBuildDate
#Attribute ID 3 Value(valueString): 201412221640%s%s
<br /> #description=gatewayVersion
#Attribute ID 2 Value(valueString): v1.17%s%s
<br /> #description=Output power 1
#Attribute ID 29 Value(valueFloat): 116%.0F%.0F VA
<br /> #description=Battery voltage
#Attribute ID 32 Value(valueFloat): 23.6%.2F%.2F V
<br /> #description=Battery current
#Attribute ID 33 Value(valueFloat): -5.7%.1F%.1F A
<br /> #description=Charge state
#Attribute ID 85 Value(valueEnum): 0%s%s
<br /> #description=Charger on/off
#Attribute ID 84 Value(valueEnum): 4%s%s
<br /> #description=Battery temperature
#Attribute ID 83 Value(valueFloat): 4.75%.1F%.1F C
#Attribute ID 82 Value(valueFloat): 0%.1F%.1F A
#Attribute ID 81 Value(valueFloat): 23.61%.2F%.2F V
<br /> #description=Solar charger version
#Attribute ID 80 Value(valueString): v2.02%s%s
<br /> #description=Switch Position
#Attribute ID 79 Value(valueEnum): 3%s%s
<br /> #description=Overload alarm
#Attribute ID 44 Value(valueEnum): 0%s%s
<br /> #description=Low battery alarm
#Attribute ID 43 Value(valueEnum): 0%s%s
<br /> #description=Temperature alarm
#Attribute ID 42 Value(valueEnum): 0%s%s
<br /> #description=VE.Bus Error
#Attribute ID 41 Value(valueEnum): 0%s%s
<br /> #description=VE.Bus state
#Attribute ID 40 Value(valueEnum): 9%s%s
#Attribute ID 35 Value(valueFloat): 0%d%d
<br /> #description=Phase count
#Attribute ID 34 Value(valueFloat): 1%d%d
<br /> #description=gatewayID
#Attribute ID 1 Value(valueEnum): 1%s%s
</p>
vrm_portal/vrm_juice_php_example.1422348701.txt.gz · Last modified: by mvader
