vrm_portal:vrm_juice_json_api_notes
drafts:vrm_juice_json_api_notes [2015-01-26 11:35] – [Juice backend work list] mvader | vrm_portal:vrm_juice_json_api_notes [2019-01-22 10:16] (current) – external edit 127.0.0.1 | ||
- | ====== VRM JSON Juice API notes (draft) ====== | + | ====== VRM JSON Juice API notes (DEPRECATED!)====== |
+ | The VRM Juice API has been deprecated in favor of the VRM v2 API. See new API documentation here: | ||
+ | https:// | ||
- | The Juice API can be used to .. . On this page there are usage notes as well as an example. The formal API documentation is found here: https:// | + | The Juice API can be used to request data from the VRM database, using JSON. On this page there are usage notes as well as an example. The formal API documentation is found here: https:// |
An example PHP file is here: [[vrm_juice_php_example]]. | An example PHP file is here: [[vrm_juice_php_example]]. | ||
Line 19: | Line 23: | ||
===== Juice backend work list ===== | ===== Juice backend work list ===== | ||
- | Below is a list of changes that will soon be implemented in the Juice API | + | |
- | - Rename the documentation, | + | |
- | - The documentation does not make clear what the difference is between sites/ | + | |
- | sites/ | + | |
- | sites/ | + | |
- | - Add a unit to the formatValueWithUnit example | + | |
- | - We need to make it possible for users to request the generated solar energy. That table stores kWh data for several things. Ofcourse we could make it all very nice and customizeable, | + | |
- | { | + | ===== Postman App for Chrome: useful to test! ===== |
- | " | + | https://chrome.google.com/ |
- | energyAttribute object: | ||
- | - To many details in an error code are visible, see other email to Rutger. | ||
vrm_portal/vrm_juice_json_api_notes.1422268549.txt.gz · Last modified: 2015-01-26 11:35 by mvader
