vrm_portal:vrm_juice_json_api_notes
VRM JSON Juice API notes (draft)
API documentation is here: https://juice.victronenergy.com/build/apidoc/.
An example PHP file is here: vrm_juice_php_example
idDataAttribute vs code
When parsing results, do not use the idDataIn the commands, do not use the
Formatting values, and adding a unit (ie. V or W)
the API will reply with a format string, usable by many programming languages. For PHP see printf
vrm_portal/vrm_juice_json_api_notes.1422267861.txt.gz · Last modified: 2015-01-26 11:24 by mvader
