vrm_portal:troubleshooting_ccgx_vrm_connectivity [2019-05-26 21:10] – mvader | vrm_portal:troubleshooting_ccgx_vrm_connectivity [2019-05-26 23:00] – [Further debugging VRM communication (advanced)] mvader | ||
Line 30: | Line 30: | ||
Note that it is not necessary for the CCGX to be addressable itself, and/or have a public IP address. Worded differently: | Note that it is not necessary for the CCGX to be addressable itself, and/or have a public IP address. Worded differently: | ||
- | ====== Further debugging VRM communication (advanced) ====== | ||
- | === Debugging the connection (advanced) === | ||
- | Data is sent to the VRM Portal using HTTP POST requests to http:// | ||
- | The output should be a line containing the text 'vrm: OK'. If it does not, or wget hangs, check your network. Apparently communication is blocked. | ||
- | === Using HTTPS instead of HTTP (advanced) === | ||
- | If your provider is blocking HTTP requests (e.g. the wget request above times out or fails), you can change the CCGX to log to the VRM portal via HTTPS: | ||
- | Verify that the setting has been changed: | ||
- | It is then recommended to reboot the CCGX to apply the changes. (Alternatively, | ||
- | After you reboot, you should see the buffer size decrease: | ||
- | root@ccgx: | ||
- | 375 | ||
- | # after rebooting | ||
- | root@ccgx: | ||
- | 362</ | ||
