vrm_portal:troubleshooting_ccgx_vrm_connectivity [2019-02-05 16:25] – [Step 2 - Verify that the CCGX has a valid IP address] mvader | vrm_portal:troubleshooting_ccgx_vrm_connectivity [2020-05-12 15:48] – mvader | ||
- | ====== Troubleshooting CCGX to VRM connectivity ====== | + | Moved here: https:// |
- | This document outlines the procedure to troubleshoot connectivity between a CCGX and the [[https:// | + | |
- | Please also read the [[https:// | + | |
- | Not using a CCGX but a Victron Global Remote or Victron Ethernet Remote? See [[https:// | + | |
- | Trouble shooting Remote Console on VRM? See last section in this document. | + | |
- | On initial contact with the VRM site it may take a few minutes for data to appear, as a newly-connected or re-connected CCGX’s presence requires that data to be filtered through our back-end systems, before the information becomes visible on the VRM site. | + | |
- | If the data backlog size continues to increase after the chosen logging interval time is met, then you have internet connectivity issues. You could try to increase the logging interval to a longer time, in order to reduce necessary bandwidth. Bandwidth requirement is quite low, so this normally only happens when using a cellular data connection. Try moving the antenna or obtain a higher gain antenna. | + | |
- | ==== Step 1. Update the CCGX to the latest available firmware ==== | + | |
- | [[ccgx: | + | |
- | ===== Step 2 - Verify that the CCGX has a valid IP address ===== | + | |
- | In the menu Settings → Ethernet or Settings → Wi-Fi, check the following: | + | |
- | - State must be ‘Connected’ | + | |
- | - There must be an IP address, that does not start with 169. | + | |
- | - There must be a gateway | + | |
- | - There must be DNS servers | + | |
- | In case there is an IP address that starts with 169, check whether your network has a DHCP server running. 99% of all networks have a DHCP server running and it is enabled by default on all well-known ADSL, cable and 3G routers. If there is no DHCP server running, then configure the ip address manually. | + | |
- | ===== Step 3 - Check connectivity between CCGX and VRM Portal ===== | + | |
- | Navigate to Settings → VRM online portal. | + | |
- | Resolution: make sure that your network has access to the internet. Plugin a laptop and navigate to [[https:// | + | |
- | If ' | + | |
- | In case all above checks have been done, internet connection is sure to work, and still 'Last contact' | + | |
- | The communication required to communicate to the VRM Portal is: | + | |
- | - Working DNS | + | |
- | Note that the CCGX does not support a proxy setup. | + | |
- | For details on the required networking, see [[https:// | + | |
- | And if that also doesn' | + | |
- | ===== Step 4 - Add the site to your VRM account ===== | + | |
- | Adding a CCGX to your account is only possible after the CCGX has made its first initial contact to the VRM Portal. | + | |
- | As long as 'Last Contact' | + | |
- | Once the internet communication is up, and 'Last contact' | + | |
- | ====== Trouble shooting Remote Console on VRM ====== | + | |
- | After enabling the feature in the CCGX setting menu, setting or disabling the password, and then restarting the CCGX, a green button will show on the VRM website. Click it to open the Remote Console. | + | |
- | - Then restart the CCGX. | + | |
- | - Make sure to update the CCGX to the latest firmware version: v2.11 or newer. | + | |
- | ==== IP Address verification ==== | + | |
- | Remote Console on VRM checks the IP Address for security reasons. | + | |
- | In case all above does not help, it might be that your internet connection very frequently changes its IP-address. And/or that the internet provider routes the different data stream over different of its routers. | + | |
- | Both of which will make the IP verification fail and therefor makes Remote Console fail. To solve this problem, contact your internet provider and/or change to a different internet provider. | + | |
- | Note that it is not necessary for the CCGX to be addressable itself, and/or have a public IP address. Worded differently: | + | |
- | ====== Further debugging VRM communication (advanced) ====== | + | |
- | === Debugging the connection (advanced) === | + | |
- | Data is sent to the VRM Portal using HTTP POST requests to http:// | + | |
- | The output should be a line containing the text 'vrm: OK'. If it does not, or wget hangs, check your network. Apparently communication is blocked. | + | |
- | === Using HTTPS instead of HTTP (advanced) === | + | |
- | If your provider is blocking HTTP requests (e.g. the wget request above times out or fails), you can change the CCGX to log to the VRM portal via HTTPS: | + | |
- | Verify that the setting has been changed: | + | |
- | It is then recommended to reboot the CCGX to apply the changes. (Alternatively, | + | |
- | After you reboot, you should see the buffer size decrease: | + | |
- | root@ccgx: | + | |
- | 375 | + | |
- | # after rebooting | + | |
- | 362</ | + | |
