vrm_portal:troubleshooting_ccgx_vrm_connectivity [2018-02-09 22:17] – [Trouble shooting Remote Console on VRM] mvader | vrm_portal:troubleshooting_ccgx_vrm_connectivity [2019-02-05 16:25] – [Step 2 - Verify that the CCGX has a valid IP address] mvader | ||
Line 19: | Line 19: | ||
===== Step 2 - Verify that the CCGX has a valid IP address ===== | ===== Step 2 - Verify that the CCGX has a valid IP address ===== | ||
- | In the menu Settings → Ethernet or Settings → Wi-Fi, State should | + | In the menu Settings → Ethernet or Settings → Wi-Fi, |
+ | - State must be ‘Connected’ | ||
+ | - There must be an IP address, that does not start with 169. | ||
+ | - There must be a gateway | ||
+ | - There must be DNS servers | ||
Line 119: | Line 124: | ||
362</ | 362</ | ||
- | ====== DISQUS Comments ====== | ||
- | ~~DISQUS~~ | ||
+ | ~~DISQUS~~ | ||
