vrm_portal:troubleshooting_ccgx_vrm_connectivity [2016-06-29 01:50] – [Enabling Remote Console from the commandline] guystewart | vrm_portal:troubleshooting_ccgx_vrm_connectivity [2020-05-12 15:48] – mvader | ||
- | ====== Troubleshooting CCGX to VRM connectivity ====== | + | Moved here: https:// |
- | This document outlines the procedure to troubleshoot connectivity between a Color Control GX and the VRM Portal, [[https:// | + | |
- | Please also read the manual of the Color Control GX on how to setup an internet connection and the logging to the VRM Portal: [[https:// | + | |
- | Not using a Color Control GX but a Victron Global Remote or Victron Ethernet Remote? See this document instead: [[https:// | + | |
- | Trouble shooting Remote Console on VRM? See last section in this document. | + | |
- | ===== Step 1 - Verify that the Color Control has received an IP address ===== | + | |
- | In the menu Settings → Ethernet or Settings → Wi-Fi, State should be ‘Connected’ and there should be an IP address that does not start with 169: | + | |
- | In case there is an IP address that starts with 169, check whether your network had a DHCP server running. 99% of all networks have a DHCP server running and it is enabled by default on all well-known ADSL, cable and 3G routers. If there is no DHCP server running, then the ip address should be configured manually. | + | |
- | ===== Step 2 - Check connectivity between CCGX and VRM Portal ===== | + | |
- | Navigate to Settings → VRM online portal. | + | |
- | 1) Check that 'Log To' is set to ' | + | |
- | 2) Check 'Last contact' | + | |
- | If ' | + | |
- | Data is sent to the VRM Portal using HTTP POST requests to http:// | + | |
- | The output should be a line containing the text 'vrm: OK'. If it does not, or wget hangs, check your network. Apparently communication is blocked. | + | |
- | === Using HTTPS instead of HTTP === | + | |
- | If your provider is blocking HTTP requests (e.g. the wget request above times out or fails), you can change the CCGX to log to the VRM portal via HTTPS: | + | |
- | Verify that the setting has been changed: | + | |
- | It is then recommended to reboot the CCGX to apply the changes. (Alternatively, | + | |
- | After you reboot, you should see the buffer size decrease: | + | |
- | root@ccgx: | + | |
- | 375 | + | |
- | # after rebooting | + | |
- | 362</ | + | |
- | ===== Step 3 - Add the site to your VRM account ===== | + | |
- | Adding a CCGX to your account is only possible after the CCGX has made its first initial contact to the VRM Portal. | + | |
- | As long as 'Last Contact' | + | |
- | Once the internet communication is up, and 'Last contact' | + | |
- | ===== General notes ===== | + | |
- | * On initial contact with the VRM site it may take a few minutes for data to appear, as a newly-connected or re-connected CCGX’s presence requires that data to be filtered through our back-end systems, before the information becomes visible on the VRM site. | + | |
- | * If the data backlog size continues to increase after the chosen logging interval time is met, then you have internet connectivity issues. You could try to increase the logging interval to a longer time, in order to reduce necessary bandwidth. Bandwidth requirement is quite low, so this only happens when using a cellular data connection, try moving the antenna or obtain a higher gain antenna. | + | |
- | ===== Trouble shooting Remote Console on VRM ===== | + | |
- | After enabling the feature in the CCGX setting menu, and then restarting the CCGX, a green button will show on the VRM website. Click it to open the Remote Console. | + | |
- | - After enabling the feature, make sure to restart the CCGX. | + | |
- | - Make sure to update to CCGX v1.32 or higher: instead of only connecting on port 80, it also tries 22 and 443 which has proven to solve connection issues for several users. | + | |
- | Remote Console on VRM uses the same reverse SSH tunnel as is used for Remote Support: outbound connection to supporthost.victronenergy.com on port 22, 80 or 443. It is not necessary to set up port forwarding in routers to use Remote Console on VRM. It is however necessary for the firewall/ | + | |
- | ===== Enabling Remote Console from the commandline ===== | + | |
- | If you have a CCGX already installed, but Remote Support is not enabled, follow these steps to enable it remotely: | + | |
- | - SSH into CCGX (get root password by emailing service@victronenergy.com) | + | |
- | - dbus -y com.victronenergy.settings / | + | |
- | - touch / | + | |
- | - Reboot CCGX via SSH (reboot) | + | |
- | - Now you should be able to access Remote Console feature from VRM | + | |
- | - If you want to set a password, go to Settings -> Remote Console | + | |
- | ~~DISQUS~~ | + | |
