vrm_portal:troubleshooting_ccgx_vrm_connectivity [2016-03-23 10:49] – Steps to enable Remote Console entirely remotely hmartin | vrm_portal:troubleshooting_ccgx_vrm_connectivity [2019-06-05 03:37] – guy_stewart | ||
- | This document outlines the procedure | + | Looking for how to trouble shoot transmission of data logs to VRM? [[https://www.victronenergy.com/ |
- | Please also read the manual of the Color Control GX on how to setup an internet connection and the logging to the VRM Portal: | + | Not using a CCGX but a Victron Global Remote or Victron Ethernet Remote? See [[https:// |
- | Not using a Color Control GX but a Victron Global Remote or Victron Ethernet Remote? See this document instead: [[https:// | ||
- | Trouble shooting Remote Console on VRM? See last section in this document. | ||
- | ===== Step 1 - Verify that the Color Control has received an IP address ===== | ||
- | In the menu Settings → Ethernet or Settings → Wi-Fi, State should be ‘Connected’ and there should be an IP address that does not start with 169: | ||
- | When using Ethernet and State shows ' | ||
- | When using Wi-Fi and the menu shows 'No Wi-Fi adapter connected' | ||
- | When using Wi-Fi and the State shows ' | ||
- | In case there is an IP address that starts with 169, check whether your network had a DHCP server running. 99% of all networks have a DHCP server running and it is enabled by default on all well-known ADSL, cable and 3G routers. If there is no DHCP server running, then the ip address should be configured manually. | ||
- | ===== Step 2 - Check connectivity between CCGX and VRM Portal ===== | ||
- | Navigate to Settings → VRM online portal. | ||
- | 1) Check that 'Log To' is set to ' | ||
- | 2) Check 'Last contact' | ||
- | If ' | ||
- | Data is sent to the VRM Portal using HTTP POST requests to http:// | ||
- | The output should be a small file containing the text 'vrm: OK'. If it does not, or wget hangs, check your network. Apparently communication is blocked. | ||
- | === Using HTTPS instead of HTTP === | ||
- | If your provider is blocking HTTP requests (e.g. the wget request above times out or fails), you can change the CCGX to log to the VRM portal via HTTPS: | ||
- | Verify that the setting has been changed: | ||
- | It is then recommended to reboot the CCGX to apply the changes. (Alternatively, | ||
- | After you reboot, you should see the buffer size decrease: | ||
- | root@ccgx: | ||
- | 375 | ||
- | # after rebooting | ||
- | root@ccgx: | ||
- | 362</ | ||
- | ===== Step 3 - Add the site to your VRM account ===== | ||
- | Adding a CCGX to your account is only possible after the CCGX has made its first initial contact to the VRM Portal. | ||
- | As long as 'Last Contact' | ||
- | Once the internet communication is up, and 'Last contact' | ||
- | ===== General notes ===== | ||
- | * On initial contact with the VRM site it may take a few minutes for data to appear, as a newly-connected or re-connected CCGX’s presence requires that data to be filtered through our back-end systems, before the information becomes visible on the VRM site. | ||
- | * If the data backlog size continues to increase after the chosen logging interval time is met, then you have internet connectivity issues. You could try to increase the logging interval to a longer time, in order to reduce necessary bandwidth. Bandwidth requirement is quite low, so this only happens when using a cellular data connection, try moving the antenna or obtain a higher gain antenna. | ||
- | ===== Trouble shooting Remote Console on VRM ===== | ||
The Remote Console on VRM feature allows full remote control of a CCGX, over the internet: | The Remote Console on VRM feature allows full remote control of a CCGX, over the internet: | ||
- | After enabling the feature in the CCGX setting menu, and then restarting the CCGX, a green button | + | After enabling the feature in the CCGX setting menu, setting or disabling the password, and then restarting the CCGX, a new Menu Option |
- | If you have a CCGX already installed, but Remote Support is not enabled, follow these steps to enable it remotely: | + | |
- | - SSH into CCGX (get root password by emailing service@victornenergy.com) | + | |
- | - dbus -y com.victronenergy.settings / | + | |
- | - echo " | + | |
- | - Reboot CCGX via SSH (reboot) | + | |
- | - Using SSH, forward the VNC port 5900 to a port on your computer (ssh -L 5900: | + | |
- | - Using VNC viewer, navigate to Settings -> Remote Console -> Disable/ | + | |
- | - Choose the one you want, reboot the CCGX again via SSH to apply | + | |
- | - Now you should be able to access Remote Console feature from VRM | + | |
Steps to take when it does not work: | Steps to take when it does not work: | ||
- First make sure that basic communication with VRM works, see above steps. | - First make sure that basic communication with VRM works, see above steps. | ||
- | - After enabling the feature, make sure to restart the CCGX. | + | - After enabling the feature, make sure to set (or disable) the password. |
- | - Make sure to update | + | - Then restart the CCGX. |
+ | - Make sure to update | ||
- After the restart, check the Remote Console on VRM status shows online or a port number. In case it says offline, or port number 0, the CCGX was unable to connect to the Remote Console server. This is normally caused by a (company) firewall, blocking the connection. The solution is then to configure an exception rules in the firewall. | - After the restart, check the Remote Console on VRM status shows online or a port number. In case it says offline, or port number 0, the CCGX was unable to connect to the Remote Console server. This is normally caused by a (company) firewall, blocking the connection. The solution is then to configure an exception rules in the firewall. | ||
+ | - Verify that your local web browser can access the [[https:// | ||
- | Remote Console on VRM uses the same reverse | + | Remote Console on VRM uses the same reverse |
- | ~~DISQUS~~ | + | ==== IP Address verification ==== |
+ | Remote Console on VRM checks the IP Address for security reasons. | ||
- | \\ | + | In case all above does not help, it might be that your internet connection very frequently changes its IP-address. And/or that the internet provider routes the different data stream over different of its routers. |
+ | Both of which will make the IP verification fail and therefor makes Remote Console fail. To solve this problem, contact your internet provider and/or change to a different internet provider. | ||
+ | Note that it is not necessary for the CCGX to be addressable itself, and/or have a public IP address. Worded differently: | ||
+ | ~~DISQUS~~ |
