vrm_portal:remote-veconfigure
vrm_portal:remote-veconfigure [2019-10-23 22:44] – guy_stewart | vrm_portal:remote-veconfigure [2020-08-17 13:22] – mvader | ||
Line 4: | Line 4: | ||
+ | ===== 2. Requirements and limitations ===== | ||
This functionality requires a [[venus-os: | This functionality requires a [[venus-os: | ||
- | - Venus OS v2.17 or later | + | - A GX Device running |
- Two way communication must be enabled | - Two way communication must be enabled | ||
Line 22: | Line 24: | ||
- | In some cases the VE.Bus system will momentarily switched off when changing the configuration. See step 4 for more details. | + | In some cases the VE.Bus system will momentarily switched off when changing the configuration. |
{{youtube> | {{youtube> | ||
Line 36: | Line 38: | ||
- the system starts with reading all the settings of each inverter/ | - the system starts with reading all the settings of each inverter/ | ||
- once all data has been gathered; its compiled into a file and uploaded to your computer. | - once all data has been gathered; its compiled into a file and uploaded to your computer. | ||
- | - Download the file to your computer | + | - Download the .RSVC file to your computer |
- | - Modify the configuration, | + | - Modify the configuration, |
- | - Upload the file to the system | + | - Upload the .RVSC file to the system |
+ | - Be Aware - If the file is saved via the File, Save As menu, instead of closing VEConfigure and confirming the changes, it will save to a new .VSC file. This file can be opened, adjusted, and used to update locally with an MK3 adapter, but it cannot be uploaded to update a remote unit. You must use the .RVSC file downloaded from the system that you intend to change the settings of, and then upload that same file once changes are made. | ||
- | ===== 3. System shutdown during reconfiguration ===== | + | ===== 4. System shutdown during reconfiguration ===== |
Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, | Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, |
vrm_portal/remote-veconfigure.txt · Last modified: 2023-05-15 14:18 by mvader
