vrm_portal:remote-veconfigure
vrm_portal:remote-veconfigure [2019-02-05 10:05] – [2. Step by step procedure] mvader | vrm_portal:remote-veconfigure [2019-08-15 12:19] – replace venus-device with GX device guy_stewart | ||
Line 5: | Line 5: | ||
- | This functionality requires a [[venus-os: | + | This functionality requires a [[venus-os: |
Line 11: | Line 11: | ||
- Two way communication must be enabled | - Two way communication must be enabled | ||
- | - The [[venus-os: | + | - The [[venus-os: |
Details: | Details: | ||
Line 29: | Line 29: | ||
- Check the requirements | - Check the requirements | ||
- Venus OS v2.17 or later | - Venus OS v2.17 or later | ||
- | - Two way communication enabled (see Settings -> Services on the [[venus-os: | + | - Two way communication enabled (see Settings -> Services on the [[venus-os: |
- Two way communication up & running: check on the Device list page on VRM | - Two way communication up & running: check on the Device list page on VRM | ||
- On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | - On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | ||
Line 39: | Line 39: | ||
- Upload the file to the system | - Upload the file to the system | ||
- | ==== 3. System shutdown during reconfiguration ==== | + | ===== 3. System shutdown during reconfiguration |
Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, | Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, | ||
+ | known issue: Venus versions v2.23 and below always reset the Multi when the following settings are changed. | ||
+ | - Battery Capacity | ||
+ | - Start and stop limits for low power AES mode | ||
+ | - State of charge when Bulk finished (only resets with Multi firmware versions < 200) | ||
Depending on how the internet communication equipment (ie. router) is powered, the internet connection might also be temporarily lost at that time. | Depending on how the internet communication equipment (ie. router) is powered, the internet connection might also be temporarily lost at that time. | ||
- | This is not a problem, as the file is first uploaded to the [[venus-os: | + | This is not a problem, as the file is first uploaded to the [[venus-os: |
vrm_portal/remote-veconfigure.txt · Last modified: 2023-05-15 14:18 by mvader
