vrm_portal:remote-veconfigure
vrm_portal:remote-veconfigure [2019-02-05 10:05] – [2. Step by step procedure] mvadervrm_portal:remote-veconfigure [2019-03-11 09:29] mvader
Line 39: Line 39:
   - Upload the file to the system   - Upload the file to the system
-==== 3. System shutdown during reconfiguration ====+===== 3. System shutdown during reconfiguration =====
 Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, will cause the inverter/charger to momentarily switch off and back on again. In such situations, VEConfig will warn when saving the settings: Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, will cause the inverter/charger to momentarily switch off and back on again. In such situations, VEConfig will warn when saving the settings:
vrm_portal/remote-veconfigure.txt · Last modified: 2023-05-15 14:18 by mvader
