vrm_portal:remote-veconfigure
vrm_portal:remote-veconfigure [2019-01-22 10:41] – external edit 127.0.0.1 | vrm_portal:remote-veconfigure [2021-12-08 10:39] – [3. Step by step procedure] mvader | ||
Line 5: | Line 5: | ||
- | This functionality requires a [[venus-os: | + | ===== 2. Requirements and limitations ===== |
+ | This functionality requires a [[venus-os: | ||
- | - Venus OS v2.17 or later | + | - A GX Device running |
- Two way communication must be enabled | - Two way communication must be enabled | ||
- | - The [[venus-os: | + | - The [[venus-os: |
+ | - [[https:// | ||
Details: | Details: | ||
Line 17: | Line 20: | ||
* Remotely changing Assistant configuration is possible. | * Remotely changing Assistant configuration is possible. | ||
* VE.Bus firmware versions 416 and 417 can not be configured remotely | * VE.Bus firmware versions 416 and 417 can not be configured remotely | ||
- | * Remote configuring firmware version 418 or later requires the CCGX or Venus GX to run v2.10 or later | + | * Remote configuring firmware version 418 or later requires the GX device |
- | * To Remote VEConfigure a system connected to the CCGX via a VE.Bus to VE.Can interface, as was done in old Hub-1 systems, this interface cable needs to run firmware version v2.05 or higher. If necessary, first update that interface cable with the [[vrm_portal: | + | * To Remote VEConfigure a system connected to the GX device |
- | In some cases the VE.Bus system will momentarily switched off when changing the configuration. See step 4 for more details. | + | In some cases the VE.Bus system will momentarily switched off when changing the configuration. |
{{youtube> | {{youtube> | ||
Line 29: | Line 32: | ||
- Check the requirements | - Check the requirements | ||
- Venus OS v2.17 or later | - Venus OS v2.17 or later | ||
- | - Two way communication enabled (see Settings -> Services | + | - Two way communication enabled (see Settings -> VRM Online Portal |
- Two way communication up & running: check on the Device list page on VRM | - Two way communication up & running: check on the Device list page on VRM | ||
- On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | - On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | ||
- | - Download | + | - Click the button and wait |
- | - Modify the configuration, save the file using the Close button in VEConfigure on the upport | + | - the system starts with reading all the settings of each inverter/ |
- | - Upload the file to the system | + | - once all data has been gathered; its compiled into a file and uploaded |
+ | - Download/ | ||
+ | - Modify the configuration | ||
+ | - Save the file using the Close button in VEConfigure on the upper right. | ||
+ | - Be Aware - You can only upload the .RVSC file when using Remote VEConfigure. If the file is saved via the File, Save As menu, instead of closing VEConfigure and confirming the changes, it will save to a new .VSC file. This file can be opened, adjusted, and used to update locally with an MK3 adapter, but it cannot be uploaded to update a remote unit. You must use the .RVSC file downloaded from the system that you intend to change the settings of, and then upload that same file once changes are made. | ||
+ | - On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | ||
+ | - Click the button and wait | ||
+ | - Click the Upload | ||
- | ==== 3. System shutdown during reconfiguration ==== | + | ===== 4. System shutdown during reconfiguration |
Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, | Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, | ||
- | Depending on how the internet communication equipment (ie. router) is powered, | + | known issue: Venus versions v2.23 and below always reset the Multi when the following settings are changed. |
+ | - Battery Capacity | ||
+ | - Start and stop limits for low power AES mode | ||
+ | - State of charge when Bulk finished (only resets with Multi firmware versions < 200) | ||
- | This is not a problem, as the file is first uploaded to the [[venus-os: | + | Depending on how the internet communication equipment (ie. router) |
+ | This is not a problem, as the file is first uploaded to the [[venus-os: |
vrm_portal/remote-veconfigure.txt · Last modified: 2023-05-15 14:18 by mvader
