vrm_portal:remote-veconfigure
vrm_portal:remote-veconfigure [2019-01-22 10:41] – external edit 127.0.0.1 | vrm_portal:remote-veconfigure [2019-03-11 09:29] – mvader | ||
Line 32: | Line 32: | ||
- Two way communication up & running: check on the Device list page on VRM | - Two way communication up & running: check on the Device list page on VRM | ||
- On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | - On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | ||
+ | - Click the button and wait | ||
+ | - the system starts with reading all the settings of each inverter/ | ||
+ | - once all data has been gathered; its compiled into a file and uploaded to your computer. | ||
- Download the file to your computer | - Download the file to your computer | ||
- Modify the configuration, | - Modify the configuration, | ||
- Upload the file to the system | - Upload the file to the system | ||
- | ==== 3. System shutdown during reconfiguration ==== | + | ===== 3. System shutdown during reconfiguration |
Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, | Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, |
vrm_portal/remote-veconfigure.txt · Last modified: 2023-05-15 14:18 by mvader
