vrm_portal:remote-veconfigure
vrm_portal:remote-veconfigure [2018-09-27 14:42] – [3. Trouble shooting] guystewart | vrm_portal:remote-veconfigure [2023-05-15 14:18] (current) – mvader | ||
- | ====== VRM: Remote VEConfigure | + | ====== VRM: Remote VEConfigure ====== |
- | This manual describes how to remotely change settings in VE.Bus | + | This manual describes how to remotely change settings in our MultiPlusses, |
- | This functionality requires the device to be updated connected to a Venus device (CCGX, Venus GX, or other). | + | ===== 2. Requirements and limitations ===== |
- | This (new) way of Remote VEConfigure replaces the previous mechanism, that used VE.Power Setup. See [[ccgx:ccgx_ve_power_setup|here]] for the manual of the old procedure. Note that, once updated to the new Venus version, it is no longer possible | + | This functionality requires a [[venus-os:start|GX device]] (Cerbo GX, or other) |
+ | - Two way communication must be enabled | ||
+ | - The [[venus-os: | ||
+ | - [[https:// | ||
Details: | Details: | ||
Line 17: | Line 20: | ||
* Remotely changing Assistant configuration is possible. | * Remotely changing Assistant configuration is possible. | ||
* VE.Bus firmware versions 416 and 417 can not be configured remotely | * VE.Bus firmware versions 416 and 417 can not be configured remotely | ||
- | * Remote configuring firmware version 418 or later requires the CCGX or Venus GX to run v2.10 or later | + | * Remote configuring firmware version 418 or later requires the GX device |
- | * To Remote VEConfigure a system connected to the CCGX via a VE.Bus to VE.Can interface, as was done in old Hub-1 systems, this interface cable needs to run firmware version v2.05 or higher. Note that it is possible to first update firmware | + | * To Remote VEConfigure a system connected to the GX device |
+ | * This (new) way of Remote VEConfigure replaces the previous mechanism, that used VE.Power Setup. See [[ccgx: | ||
+ | * The system protects against accidentally sending settings from one system to another. To that purpose, it will compare the serial numbers of the installed inverter/ | ||
+ | * For systems consisting of multiple inverter/ | ||
- | Some change will cause the VE.Bus system | + | In some cases the VE.Bus system |
- | ===== 2. Procedure | + | ===== 3. Step by step procedure |
- | === Step 1. Go to Remote VEConfigure on the VRM Portal === | + | {{youtube> |
- | FIXME add screenshot | + | - Check the requirements |
+ | - Venus OS v2.17 or later | ||
+ | - Two way communication enabled (see Settings -> VRM Online Portal on the [[venus-os: | ||
+ | - Two way communication up & running: check on the Device list page on VRM | ||
+ | - On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | ||
+ | - Click the button and wait | ||
+ | - the system starts with reading all the settings of each inverter/ | ||
+ | - once all data has been gathered; its compiled into a file and uploaded to your computer. | ||
+ | - Download/ | ||
+ | - Modify the configuration by opening the downloaded .RSVC file in VEConfigure. | ||
+ | - Save the file using the Close button in VEConfigure on the upper right. You will be asked if you wish to save the changes. Changes can be saved to both the .RVSC file, and also to another seperate .VSC file. | ||
+ | - Be Aware - You can only upload the .RVSC file when using Remote VEConfigure. If the file is saved via the File, Save As menu, instead of closing VEConfigure and confirming the changes, it will save to a new .VSC file. This file can be opened, adjusted, and used to update locally with an MK3 adapter, but it cannot be uploaded to update a remote unit. You must use the .RVSC file downloaded from the system that you intend to change the settings of, and then upload that same file once changes are made. | ||
+ | - Click the Upload button, select the .RVSC file, and OK to send it to the system via the VRM | ||
- | === Step 2. Download the file to your computer | + | ===== 4. System shutdown during reconfiguration |
- | FIXME add screenshot once last changes have been done. | + | |
- | === Step 3. Modify the configuration | + | |
- | To save the file, close it with the cross on the upper right. It will automatically save the settings. It is not necessary, and also not possible, to save if via the file menu. | + | |
- | === Step 4. Upload the configuration to the system === | + | |
- | Open your browser again, and there upload the changed file. | + | |
- | __System shutdown during reconfiguration__ | + | |
Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, | Many settings can be changed without resulting in a shutdown during the re-configuration. Some settings though, such as a changed Assistants configuration, | ||
+ | known issue: Venus versions v2.23 and below always reset the Multi when the following settings are changed. | ||
+ | - Battery Capacity | ||
+ | - Start and stop limits for low power AES mode | ||
+ | - State of charge when Bulk finished (only resets with Multi firmware versions < 200) | ||
Depending on how the internet communication equipment (ie. router) is powered, the internet connection might also be temporarily lost at that time. | Depending on how the internet communication equipment (ie. router) is powered, the internet connection might also be temporarily lost at that time. | ||
- | This is not a problem, as the file is first uploaded to the Venus device, and only once received and verified it will be written to the VE.Bus system. | + | This is not a problem, as the file is first uploaded to the [[venus-os: |
- | It is required to make sure that that the Venus device is not switched off during the reconfiguration. In other words: do not power that with an AC adapter on the output of the system. | + | |
- | ===== 3. Trouble shooting ===== | + | |
- | FIXME | + | |
- | ===== 4. How to Video ===== | + | |
- | {{youtube> | + | |
- | ===== 5. Disqus ===== | + | |
vrm_portal/remote-veconfigure.txt · Last modified: 2023-05-15 14:18 by mvader
