vrm_portal:remote-veconfigure
vrm_portal:remote-veconfigure [2021-12-08 10:39] – [3. Step by step procedure] mvader | vrm_portal:remote-veconfigure [2023-05-15 14:18] (current) – mvader | ||
Line 23: | Line 23: | ||
* To Remote VEConfigure a system connected to the GX device via a VE.Bus to VE.Can interface, as was done in old Hub-1 systems, this interface cable needs to run firmware version v2.05 or higher. If necessary, first update that interface cable with the [[vrm_portal: | * To Remote VEConfigure a system connected to the GX device via a VE.Bus to VE.Can interface, as was done in old Hub-1 systems, this interface cable needs to run firmware version v2.05 or higher. If necessary, first update that interface cable with the [[vrm_portal: | ||
+ | * The system protects against accidentally sending settings from one system to another. To that purpose, it will compare the serial numbers of the installed inverter/ | ||
+ | * For systems consisting of multiple inverter/ | ||
In some cases the VE.Bus system will momentarily switched off when changing the configuration. | In some cases the VE.Bus system will momentarily switched off when changing the configuration. |
vrm_portal/remote-veconfigure.txt · Last modified: 2023-05-15 14:18 by mvader
