vrm_portal:remote-firmware-update [2021-03-20 03:25] – guystewart | vrm_portal:remote-firmware-update [2023-10-10 11:43] (current) – [2.2 Compatible products] sloges | ||
Line 10: | Line 10: | ||
- Works from laptop, tablet & phone | - Works from laptop, tablet & phone | ||
- No need to find the right firmware file: the system has all, and will clearly indicate that a newer version is available. | - No need to find the right firmware file: the system has all, and will clearly indicate that a newer version is available. | ||
- | - Works with VE.Direct | + | - For supported |
- | - Works with VE.Can products: MPPT VE.Can Solar Chargers, Skylla-i, and more. | + | |
+ | Demonstration video: | ||
{{youtube> | {{youtube> | ||
Line 20: | Line 18: | ||
==== 2.1 Requirements ==== | ==== 2.1 Requirements ==== | ||
- | * Venus OS v2.17 or later | + | * GX device must be running |
* System must be connected to the internet and communicating to the [[https:// | * System must be connected to the internet and communicating to the [[https:// | ||
* The '' | * The '' | ||
Line 28: | Line 26: | ||
Products connected via VE.Direct communication port: | Products connected via VE.Direct communication port: | ||
- | * MPPT Solar Charge Controllers (1) | + | * MPPT Solar Charge Controllers, including MPPT RS (See note 1 below) |
* BMV Battery Monitors | * BMV Battery Monitors | ||
- | * Phoenix Inverters | + | * SmartShunts |
+ | * Inverter VE.Direct | ||
+ | * Smart IP43 Charger | ||
Products connected via VE.Can communication port: | Products connected via VE.Can communication port: | ||
* MPPT Solar Charge Controllers | * MPPT Solar Charge Controllers | ||
* Skylla-i battery chargers | * Skylla-i battery chargers | ||
+ | * Lynx Smart BMS | ||
+ | Victron Energy Multis, Quattros, other VE.Bus-connected Inverter/ | ||
==== 2.3 How does it work? ==== | ==== 2.3 How does it work? ==== | ||
Line 67: | Line 69: | ||
Updating firmware on a BMV that is connected via a [[https:// | Updating firmware on a BMV that is connected via a [[https:// | ||
- | === VE.Bus Products (Multis, Quattros, high power Inverters) | + | === Lynx Ion BMS Series |
- | Remotely updating firmware in VE.Bus products | + | (note that this does not apply to the Lynx Smart BMS) |
- | === Lynx BMS Series === | + | |
Remotely updating firmware of these Lynx series of products is not possible: | Remotely updating firmware of these Lynx series of products is not possible: |
