vrm_portal:remote-firmware-update [2019-08-15 12:22] – [2.1 Requirements] guy_stewart | vrm_portal:remote-firmware-update [2019-08-20 15:45] – [2.6 Limitations] marmour | ||
Line 79: | Line 79: | ||
* The firmware library does not have the files. Download the file from [[https:// | * The firmware library does not have the files. Download the file from [[https:// | ||
* Make sure that the [[venus-os: | * Make sure that the [[venus-os: | ||
- | * In case the update fails, it can be retried; just like all other products. But in case of the Lynx BMS, this has to be done within 5 minutes. Otherwise it will will go to sleep mode and a push on the start button is required. | + | * In case the update fails, it can be retried; just like all other products. But in case of the Lynx BMS, this has to be done within 5 minutes. Otherwise it will go to sleep mode and a push on the start button is required. |
