vrm_portal:remote-firmware-update [2018-09-27 16:05] – [2.1 Requirements] marmour | vrm_portal:remote-firmware-update [2021-03-20 03:25] – guystewart | ||
- | This manual describes how to remotely update firmware. This functionality requires the device to be updated connected to a Venus-device (CCGX, Venus GX, or other). | + | This manual describes how to remotely update firmware. This functionality requires the device to be updated connected to a [[venus-os: |
Features: | Features: | ||
Line 12: | Line 12: | ||
- Works with VE.Direct products: MPPT Solar Chargers, BMV Battery Monitor, Phoenix Inverters, and more. | - Works with VE.Direct products: MPPT Solar Chargers, BMV Battery Monitor, Phoenix Inverters, and more. | ||
- Works with VE.Can products: MPPT VE.Can Solar Chargers, Skylla-i, and more. | - Works with VE.Can products: MPPT VE.Can Solar Chargers, Skylla-i, and more. | ||
+ | {{youtube> | ||
===== 2. Details ===== | ===== 2. Details ===== | ||
Line 18: | Line 22: | ||
* Venus OS v2.17 or later | * Venus OS v2.17 or later | ||
* System must be connected to the internet and communicating to the [[https:// | * System must be connected to the internet and communicating to the [[https:// | ||
- | * The '' | + | * The '' |
==== 2.2 Compatible products ==== | ==== 2.2 Compatible products ==== | ||
Line 36: | Line 40: | ||
- The new firmware file is first uploaded to the system. | - The new firmware file is first uploaded to the system. | ||
- | - Once received and verified, the Venus-device starts updating the firmware of the connected device. This eliminates any problems that could be caused by an intermittent internet connection. In case the internet does break while performing the update, the system will continue with the firmware update. | + | - Once received and verified, the [[venus-os: |
==== 2.4 Where to find the firmware file? ==== | ==== 2.4 Where to find the firmware file? ==== | ||
Line 55: | Line 59: | ||
==== 2.6 Limitations ===== | ==== 2.6 Limitations ===== | ||
- | === General === | ||
- | Remotely changing settings currently only works for VE.Bus products: Multis, Quattros, and high power Inverters. For all other products, MPPT Solar Charge Controllers, | ||
=== MPPT Solar Chargers connected with VE.Direct === | === MPPT Solar Chargers connected with VE.Direct === | ||
Line 76: | Line 77: | ||
Remote updating the Lynx Ion BMS 150A, 400A, 600A and 1000A model is possible. Notes: | Remote updating the Lynx Ion BMS 150A, 400A, 600A and 1000A model is possible. Notes: | ||
- | * The firmware library does not have the files. Download the file from [[https:// | + | * The firmware library does not always |
- | * Make sure that the Venus-device is powered on the '' | + | * Make sure that the [[venus-os: |
+ | * In case the update fails, it can be retried; just like all other products. But in case of the Lynx BMS, this has to be done within 5 minutes. Otherwise it will go to sleep mode and a push on the start button is required. | ||
Line 84: | Line 86: | ||
===== 3. Step by step instructions ===== | ===== 3. Step by step instructions ===== | ||
- | ==== Step 1. Go to Firmware updates on the VRM Portal | + | === Step 1. Go to Firmware updates on the VRM Portal === |
- | ==== Step 2. Update process | + | === Step 2. Update process === |
- | ==== Step 3. Finished | + | === Step 3. Finished === |
+ | ===== 4. Uploading a firmware file ==== | ||
- | ===== 4. Trouble shooting ===== | + | In most situations the system will already have a firmware file available; no need to upload anything yourself. Sometimes however it is necessary to upload a file from your computer; and this chapter explains how that's done. |
- | === Error 1341 Not updatable | + | First start with having the system list the updatable |
- | Typically shows when it is not a Victron product. | + | {{ : |
- | === Error 1342 Not updatable === | + | Click the three dots on the right of a line; the upload file button will show. |
- | Updatable not true as returned by the device/ | + | Click that, select |
+ | ===== 5. Trouble shooting ===== | ||
+ | === Error 1341 Not updatable === | ||
+ | Typically shows when it is not a Victron product. | ||
=== Error 1343 Not updatable: Blacklisted === | === Error 1343 Not updatable: Blacklisted === | ||
See limitations chapter above. The product you are trying to update cannot be updated remotely. | See limitations chapter above. The product you are trying to update cannot be updated remotely. |
