vrm_portal:remote-firmware-update [2018-03-29 09:09] – [3. Trouble shooting] b1ke | vrm_portal:remote-firmware-update [2023-10-10 11:43] (current) – [2.2 Compatible products] sloges | ||
- | ====== VRM: Remote firmware update | + | ====== VRM: Remote firmware update ====== |
- | This manual describes how to remotely update firmware. This functionality requires the device to be updated connected to a Venus-device (CCGX, Venus GX, or other). See [[ccgx: | + | This manual describes how to remotely update firmware. This functionality requires the device to be updated connected to a [[venus-os: |
- | The here described features & functionality replaces the similar features in VE Power Setup. See | + | Features: |
- | [[ccgx:ccgx_ve_power_setup|here]] for the manual of the old procedure. Note that, once updated | + | - Remotely update internet-connected products straight from the [[https:// |
+ | - No need to install any software | ||
+ | - Works from laptop, tablet & phone | ||
+ | - No need to find the right firmware file: the system has all, and will clearly indicate that a newer version | ||
+ | - For supported products, see below | ||
- | It is not necessary to yourself get the latest firmware version from [[https:// | + | Demonstration video: |
+ | {{youtube> | ||
+ | ===== 2. Details ===== | ||
+ | ==== 2.1 Requirements ==== | ||
+ | * GX device must be running Venus OS v2.17 or later | ||
+ | * System must be connected to the internet and communicating to the [[https:// | ||
+ | * The '' | ||
+ | ==== 2.2 Compatible products ==== | ||
Products ranges for which the firmware can be updated remotely: | Products ranges for which the firmware can be updated remotely: | ||
- | * Devices connected via VE.Direct: MPPT Solar Charge Controllers (1), BMV Battery Monitors, and more. | ||
- | * Devices connected on a VE.Can network: MPPT Solar Charge Controllers, | ||
- | Limitations: | + | Products |
- | * Updating firmware on a BMVs that is connected via a [[https:// | + | * MPPT Solar Charge Controllers, |
- | * Remotely updating firmware in VE.Bus products (Inverters, Multis and Quattros) is not possible and will also not become possible. | + | * BMV Battery Monitors |
- | * Remotely changing settings of MPPT Solar Charge Controllers, | + | * SmartShunts |
+ | * Inverter | ||
+ | * Smart IP43 Charger | ||
- | Requirements: | + | Products connected via VE.Can communication port: |
- | * Venus OS v2.20 or later | + | * MPPT Solar Charge Controllers |
- | * System must connected | + | * Skylla-i battery chargers |
+ | * Lynx Smart BMS | ||
+ | Victron Energy Multis, Quattros, other VE.Bus-connected | ||
+ | ==== 2.3 How does it work? ==== | ||
- | Process: | ||
- The new firmware file is first uploaded to the system. | - The new firmware file is first uploaded to the system. | ||
- | - Once received and verified, the Venus-device starts updating the firmware of the connected device. This eliminates any problems that could be caused by an intermittent internet connection. In case the internet does break while performing the update, the system will continue with the firmware update. | + | - Once received and verified, the [[venus-os: |
- | (1) During the update, any configuration in the device will be maintained. In the event that the update fails, which is unlikely, VE.Direct MPPT Charge Controllers will have lost their configuration. Also it is not possible | + | ==== 2.4 Where to find the firmware file? ==== |
- | ===== 2. Notes on firmware updating in general | + | It is not necessary |
+ | ==== 2.5 Notes on firmware updating in general ==== | ||
There is a lot that can be said about firmware updating: | There is a lot that can be said about firmware updating: | ||
Line 40: | Line 59: | ||
Change logs can be downloaded from [[https:// | Change logs can be downloaded from [[https:// | ||
+ | ==== 2.6 Limitations ===== | ||
+ | === MPPT Solar Chargers connected with VE.Direct === | ||
+ | During the update of a VE.Direct connected MPPT Solar Charger, any configuration in the device will be maintained, but in the event that the update fails, which is unlikely, VE.Direct MPPT Charge Controllers will have lost their configuration. Also it is not possible to reconfigure them remotely. All other devices work with a different process and will not lose their settings during an update; even it fails. | ||
+ | === BMVs === | ||
+ | Updating firmware on a BMV that is connected via a [[https:// | ||
+ | === Lynx Ion BMS Series === | ||
+ | (note that this does not apply to the Lynx Smart BMS) | ||
+ | Remotely updating firmware of these Lynx series of products is not possible: | ||
+ | * Lynx Ion - product-id 0x0142 | ||
+ | * Lynx Ion + Shunt 350 & 600A model: product-id 0xA130 | ||
+ | Remote updating the Lynx Ion BMS 150A, 400A, 600A and 1000A model is possible. Notes: | ||
+ | * The firmware library does not always have the files. Download the file from [[https:// | ||
+ | * Make sure that the [[venus-os: | ||
+ | * In case the update fails, it can be retried; just like all other products. But in case of the Lynx BMS, this has to be done within 5 minutes. Otherwise it will go to sleep mode and a push on the start button is required. | ||
- | ===== 3. Procedure | + | ===== 3. Step by step instructions |
- | === 1. Go to Firmware updates on the VRM Portal === | + | === Step 1. Go to Firmware updates on the VRM Portal === |
- | === 2. Update process === | + | === Step 2. Update process === |
- | === 3. Finished === | + | === Step 3. Finished === |
+ | ===== 4. Uploading a firmware file ==== | ||
- | ===== 3. Trouble shooting ===== | + | In most situations the system will already have a firmware file available; no need to upload anything yourself. Sometimes however it is necessary to upload a file from your computer; and this chapter explains how that's done. |
- | === Not updatable | + | First start with having the system list the updatable |
- | Devices that are in boot mode cannot be updated remotely. | + | {{ : |
- | they are running in an minimal failsafe mode allowing an firmware update through physical conenction being usb or a bleutooth dongle. | + | |
- | === Not updatable (Updatable=False) === | + | Click the three dots on the right of a line; the upload file button will show. |
- | MPPT controllers connected through CAN-BUS are not able to remotely have their firmware updated. | + | Click that, select the file on your computer; and the rest of the procedure will continue as explained above. |
- | FIXME can this ever happen? | + | ===== 5. Trouble shooting ===== |
- | FIXME Are there any other reasons for a device to be Not updatable? | + | === Error 1341 Not updatable |
- | FIXME how to trouble shoot Connection issues? See also same chapters in VE Power setup documentation, | + | Typically shows when it is not a Victron product. |
- | ===== 4. Disqus ===== | + | === Error 1343 Not updatable: Blacklisted |
- | ~~DISQUS~~ | + | See limitations chapter above. The product you are trying to update cannot be updated remotely. |
