vrm_portal:getting_started
vrm_portal:getting_started [2017-02-06 22:23] – [More tips and tricks] mvader | vrm_portal:getting_started [2022-12-21 03:28] (current) – [Getting started with VRM] guy_stewart | ||
====== Getting started with VRM ====== | ====== Getting started with VRM ====== | ||
- | There are two separate steps that need to be taken. First, you need to create a VRM user account. And after that the installation, | + | To connect your system to the VRM Portal, there are two separate steps that need to be taken. First, you need to create a VRM user account. And then secondly, |
+ | A single user can have access to several installations, | ||
===== Requirements ===== | ===== Requirements ===== | ||
Line 9: | Line 11: | ||
- A computer connected to the Internet | - A computer connected to the Internet | ||
- The VRM Portal ID, which uniquely identifies your system. | - The VRM Portal ID, which uniquely identifies your system. | ||
- | - Color Control | + | - GX device menu (Cerbo GX with GX touch display): the VRM Portal ID can be found in the menu Settings → VRM Logger. It looks like this: be300d83ff04. For more information, |
+ | - Venus GX & Cerbo GX: the VRM Portal ID is printed on a label on the side. For more information, | ||
+ | - [[https:// | ||
- VGR, VGR2 and VER: the VRM Portal ID is the IMEI number. It is written on a label on the back of the modem, and on a label on the outside of the carton. It can also be requested by sending a text message to the modem with the command ' | - VGR, VGR2 and VER: the VRM Portal ID is the IMEI number. It is written on a label on the back of the modem, and on a label on the outside of the carton. It can also be requested by sending a text message to the modem with the command ' | ||
+ | The system | ||
- | Note: it is recommended, | + | Note: it is recommended, |
===== Step 1. Create a user account ===== | ===== Step 1. Create a user account ===== | ||
Line 29: | Line 35: | ||
4. You will now receive a confirmation email with a link to activate your account. | 4. You will now receive a confirmation email with a link to activate your account. | ||
- | Account creation is now finished, click add installation to continue pairing | + | Account creation is now finished, click add installation to continue pairing |
===== Step 2. Add an installation to the user account ===== | ===== Step 2. Add an installation to the user account ===== | ||
- | Note: make sure that the VGR/ | + | Note: make sure that the system |
- | It is only possible | + | Adding an installation |
- | Steps to add a installation: | + | Steps to add an installation: |
1. Select the product you want to add. | 1. Select the product you want to add. | ||
Line 43: | Line 49: | ||
- | 2. Enter the IMEI or MAC Address number for one of the VGR, VER or CCGX products. | + | 2. Enter the IMEI or MAC Address number for one of the VGR, VER or GX device |
- | 3. Click ' | + | 3. Click ' |
+ | In case you are the first user to add this installation to your account, you will automatically have Admin rights for this installation. Any subsequent users that add this installation to their account will become a normal user, that cannot change any settings. An Admin user can assign Admin rights to other users on the Settings page. | ||
+ | When a " | ||
4. The first page will be as the screen below. If there is no data yet, please check the [[vrm_portal: | 4. The first page will be as the screen below. If there is no data yet, please check the [[vrm_portal: | ||
Line 53: | Line 63: | ||
- | 5. Once more than one installation is linked to your VRM user account, you will see all of them on a map. When multiple | + | 5. Once more than one installation is linked to your VRM user account, you will see all of them on a map. When multiple |
Line 74: | Line 84: | ||
* Set the location of the installation by dragging the cursor to the right place. This automatically sets the timezone that is used for all x-axes on the graphs as well. | * Set the location of the installation by dragging the cursor to the right place. This automatically sets the timezone that is used for all x-axes on the graphs as well. | ||
- | **Users** | + | ==== Users ==== |
* Configure which users are admin and which not. Admins can change settings on all installations for which they have admin rights. | * Configure which users are admin and which not. Admins can change settings on all installations for which they have admin rights. | ||
* Invite new users to this installation. | * Invite new users to this installation. | ||
**Alarm rules** | **Alarm rules** | ||
Line 94: | Line 106: | ||
* Do not forget to install the VRM app on your phone. It is available for free in both the Apple store and the Google Play store for Android. For Android, it is also possible to download the APK files on our [[https:// | * Do not forget to install the VRM app on your phone. It is available for free in both the Apple store and the Google Play store for Android. For Android, it is also possible to download the APK files on our [[https:// | ||
- | * See the [[: | ||
- | * We maintain a [[: | ||
- | ===== Increased security when logging into your VRM installation ===== | ||
- | See [[https:// | ||
vrm_portal/getting_started.1486416213.txt.gz · Last modified: 2017-02-06 22:23 by mvader
