vrm_portal:getting_started
vrm_portal:getting_started [2020-11-09 14:10] – guy_stewart | vrm_portal:getting_started [2021-03-20 02:53] – guystewart | ||
Line 11: | Line 11: | ||
- A computer connected to the Internet | - A computer connected to the Internet | ||
- The VRM Portal ID, which uniquely identifies your system. | - The VRM Portal ID, which uniquely identifies your system. | ||
- | - Color Control | + | - GX device menu (Cerbo GX with GX touch display): the VRM Portal ID can be found in the menu Settings → VRM Logger. It looks like this: be300d83ff04. For more information, |
- | - Venus GX: the VRM Portal ID is printed on a label on the side. For more information, | + | - Venus GX & Cerbo GX: the VRM Portal ID is printed on a label on the side. For more information, |
- [[https:// | - [[https:// | ||
- VGR, VGR2 and VER: the VRM Portal ID is the IMEI number. It is written on a label on the back of the modem, and on a label on the outside of the carton. It can also be requested by sending a text message to the modem with the command ' | - VGR, VGR2 and VER: the VRM Portal ID is the IMEI number. It is written on a label on the back of the modem, and on a label on the outside of the carton. It can also be requested by sending a text message to the modem with the command ' | ||
Line 19: | Line 19: | ||
The system needs to have had a successful connection to the VRM Portal, before adding the installation to your user account on the VRM Portal. | The system needs to have had a successful connection to the VRM Portal, before adding the installation to your user account on the VRM Portal. | ||
- | Note: it is recommended, | + | Note: it is recommended, |
===== Step 1. Create a user account ===== | ===== Step 1. Create a user account ===== | ||
Line 49: | Line 49: | ||
- | 2. Enter the IMEI or MAC Address number for one of the VGR, VER or CCGX products. | + | 2. Enter the IMEI or MAC Address number for one of the VGR, VER or GX device |
vrm_portal/getting_started.txt · Last modified: 2022-12-21 03:28 by guy_stewart
