vrm_portal:getting_started
vrm_portal:getting_started [2019-01-22 10:16] – external edit 127.0.0.1 | vrm_portal:getting_started [2020-09-22 12:40] – mvader | ||
====== Getting started with VRM ====== | ====== Getting started with VRM ====== | ||
- | There are two separate steps that need to be taken. First, you need to create a VRM user account. And after that the installation, | + | To connect your system to the VRM Portal, there are two separate steps that need to be taken. First, you need to create a VRM user account. And then secondly, |
+ | It is possible to pair one installation to multiple user accounts. And also it's possible to have multiple users connected to the same installation. | ||
===== Requirements ===== | ===== Requirements ===== | ||
Line 11: | Line 13: | ||
- Color Control GX: the VRM Portal ID can be found in the menu Settings → VRM Logger. It looks like this: be300d83ff04. For more information, | - Color Control GX: the VRM Portal ID can be found in the menu Settings → VRM Logger. It looks like this: be300d83ff04. For more information, | ||
- Venus GX: the VRM Portal ID is printed on a label on the side. For more information, | - Venus GX: the VRM Portal ID is printed on a label on the side. For more information, | ||
+ | - [[https:// | ||
- VGR, VGR2 and VER: the VRM Portal ID is the IMEI number. It is written on a label on the back of the modem, and on a label on the outside of the carton. It can also be requested by sending a text message to the modem with the command ' | - VGR, VGR2 and VER: the VRM Portal ID is the IMEI number. It is written on a label on the back of the modem, and on a label on the outside of the carton. It can also be requested by sending a text message to the modem with the command ' | ||
The system needs to have had a successful connection to the VRM Portal, before adding the installation to your user account on the VRM Portal. | The system needs to have had a successful connection to the VRM Portal, before adding the installation to your user account on the VRM Portal. | ||
Line 31: | Line 35: | ||
4. You will now receive a confirmation email with a link to activate your account. | 4. You will now receive a confirmation email with a link to activate your account. | ||
- | Account creation is now finished, click add installation to continue pairing | + | Account creation is now finished, click add installation to continue pairing |
===== Step 2. Add an installation to the user account ===== | ===== Step 2. Add an installation to the user account ===== | ||
Line 39: | Line 43: | ||
Adding an installation is only possible __after__ the VRM Portal has received the first data transmission of your system. | Adding an installation is only possible __after__ the VRM Portal has received the first data transmission of your system. | ||
- | Steps to add a installation: | + | Steps to add an installation: |
1. Select the product you want to add. | 1. Select the product you want to add. | ||
Line 59: | Line 63: | ||
- | 5. Once more than one installation is linked to your VRM user account, you will see all of them on a map. When multiple | + | 5. Once more than one installation is linked to your VRM user account, you will see all of them on a map. When multiple |
Line 109: | Line 113: | ||
- | ~~DISQUS~~ | ||
vrm_portal/getting_started.txt · Last modified: 2022-12-21 03:28 by guy_stewart
