vrm_portal:getting_started
vrm_portal:getting_started [2019-01-22 10:16] – external edit 127.0.0.1vrm_portal:getting_started [2019-05-23 16:40] guy_stewart
Line 11: Line 11:
       - Color Control GX: the VRM Portal ID can be found in the menu Settings → VRM Logger. It looks like this: be300d83ff04. For more information, see [[:vrm_portal:troubleshooting_ccgx_vrm_connectivity|Troubleshooting VRM Portal Connectivity for a CCGX]].       - Color Control GX: the VRM Portal ID can be found in the menu Settings → VRM Logger. It looks like this: be300d83ff04. For more information, see [[:vrm_portal:troubleshooting_ccgx_vrm_connectivity|Troubleshooting VRM Portal Connectivity for a CCGX]].
       - Venus GX: the VRM Portal ID is printed on a label on the side. For more information, see [[:vrm_portal:troubleshooting_ccgx_vrm_connectivity|Troubleshooting VRM Portal Connectivity for a CCGX]].       - Venus GX: the VRM Portal ID is printed on a label on the side. For more information, see [[:vrm_portal:troubleshooting_ccgx_vrm_connectivity|Troubleshooting VRM Portal Connectivity for a CCGX]].
 +      - [[https://www.victronenergy.com/live/venus-os:start|A GX Device]]
       - VGR, VGR2 and VER: the VRM Portal ID is the IMEI number. It is written on a label on the back of the modem, and on a label on the outside of the carton. It can also be requested by sending a text message to the modem with the command 'GSM'. For more information, see [[https://www.victronenergy.com/upload/documents/Manual-Troubleshooting-VGR-connectivity-EN.pdf|Troubleshooting VRM Portal Connectivity for a VGR]].       - VGR, VGR2 and VER: the VRM Portal ID is the IMEI number. It is written on a label on the back of the modem, and on a label on the outside of the carton. It can also be requested by sending a text message to the modem with the command 'GSM'. For more information, see [[https://www.victronenergy.com/upload/documents/Manual-Troubleshooting-VGR-connectivity-EN.pdf|Troubleshooting VRM Portal Connectivity for a VGR]].
 +      - [[https://www.victronenergy.com/panel-systems-remote-monitoring/ve-direct-lorawan|LoRaWan Device]]
 The system needs to have had a successful connection to the VRM Portal, before adding the installation to your user account on the VRM Portal. The system needs to have had a successful connection to the VRM Portal, before adding the installation to your user account on the VRM Portal.
vrm_portal/getting_started.txt · Last modified: 2022-12-21 03:28 by guy_stewart
