vrm_portal:getting_started
vrm_portal:getting_started [2017-07-24 20:55] – mvader | vrm_portal:getting_started [2019-01-21 11:15] – [DISQUS] ictbeheer | ||
Line 37: | Line 37: | ||
Note: make sure that the system has already started communicating with the VRM Portal. Or, in case it is an off-grid installation where a SDcard or USB-Stick is used, first upload the data file. | Note: make sure that the system has already started communicating with the VRM Portal. Or, in case it is an off-grid installation where a SDcard or USB-Stick is used, first upload the data file. | ||
- | Adding an installation is only possible __after__ | + | Adding an installation is only possible __after__ |
Steps to add a installation: | Steps to add a installation: | ||
Line 108: | Line 108: | ||
See [[https:// | See [[https:// | ||
vrm_portal/getting_started.txt · Last modified: 2022-12-21 03:28 by guy_stewart
