vrm_portal:dashboard
vrm_portal:dashboard [2022-04-14 06:09] – [3.1 Inverter controls in VRM] guystewart | vrm_portal:dashboard [2022-09-13 09:35] – [3.1 Inverter controls in VRM] guystewart | ||
Line 116: | Line 116: | ||
===== 3. Control your devices in VRM ===== | ===== 3. Control your devices in VRM ===== | ||
- | VRM offers control over some of your Victron devices, straight from the VRM dashboard. With this feature, you can quickly adjust the settings | + | VRM offers control over some of your Victron devices, straight from the VRM dashboard. With this feature, you can quickly adjust the settings ESS or relay switches, without needing to open the remote console. |
To access it, head to your VRM dashboard. | To access it, head to your VRM dashboard. | ||
Line 126: | Line 126: | ||
==== 3.1 Inverter controls in VRM ==== | ==== 3.1 Inverter controls in VRM ==== | ||
- | Note - while initially | + | Inverter controls can be made available |
+ | Note - there is a limitation where these controls are not available when using a Digital Multi Control, or VE.Bus BMS v1 in the system. | ||
==== 3.2 ESS controls in VRM ==== | ==== 3.2 ESS controls in VRM ==== | ||
vrm_portal/dashboard.txt · Last modified: 2023-10-10 11:50 by sloges
