vrm_portal:dashboard
vrm_portal:dashboard [2021-07-30 00:47] – [1.5. Details per section] guystewart | vrm_portal:dashboard [2022-07-03 12:47] – [3.1 Inverter controls in VRM] guystewart | ||
Line 112: | Line 112: | ||
+ | Inverter controls can be made available on the VRM Dashboard, but require an additional step to enable in the Settings for that specific VRM Installation. This is to prevent accidentally switching off the system. | ||
+ | Note - there is a limitation where these controls are not available when using a Digital Multi Control, or VE.Bus BMS in the system. | ||
vrm_portal/dashboard.txt · Last modified: 2023-10-10 11:50 by sloges
