VRM Portal changelog
2022-04-28
2022-04-25
Device list: Allow to separately click on the remote
LAN IP addresses.
Advanced: Improve the grid of the temperature, humidity and pressure chart.
Advanced: Switch around min and max cell voltage in the tooltip.
Various styling improvements
2022-04-20
Dashboard: Improve showing battery temperature for installation with multiple temperature sources.
Advanced: Fix tag positioning in Firefox.
Custom widgets: Improve creation modal size and position.
2022-04-19
2022-04-15
Advanced: The tooltip labels for state graphs on the advanced page stay within the graph.
Dashboard: Make battery states translatable.
Dashboard: Replace EVCS Max Charge Current with Total Energy.
Redirect from the VRM landing page to the VRM product page.
2022-04-13
2022-04-12
Custom widget: Add device instance dumber for series with the same description.
Dashboard: Remove EVCS line artefact.
Dark mode improvements: Safari notch color, modal headers, scroll bars.
Improve loading translations for slow connections.
Update translations for all languages
2022-04-10
2022-04-07
2022-04-01
2022-03-31
Advanced: Only show series for which there is data inside a widget.
Dark mode styling improvements in various pages.
Installation groups: Automatically add tags to installations that are part of a group so they can be easily filtered in the installation overview.
Update translations.
2022-03-30
2022-03-23
2022-03-16
2022-03-15
2022-03-14
2022-03-11
Dashboard: Fix double AC Loads frequency for system with more than one VE.Bus device.
Advanced: Only show relevant series in widgets with multiple series. For example, do not show humidity and pressure for sensors that collect only temperature.
2022-03-09
Add dark mode.
Add “Preferences” menu.
2022-03-09
2022-03-03
2022-02-25
2022-02-22
2022-02-21
2022-02-18
2022-02-08
2022-02-01
Remote firmware updates: Allow updating RS products when not all the controllers have working firmware.
Advanced: Add widgets for AC Meters and DC Loads.
Advanced: Combine the temperature, humidity and pressure widgets into one.
2022-01-31
2022-01-20
2022-01-18
Dashboard: Add ESS states to the battery tile.
Dashboard: Add last updated to temperature tiles.
Device list: Improve the display of custom names and device instances.
2022-01-17
2022-01-12
2022-01-08
2022-01-07
Advanced page: Improve GPS widget by making the header stay on top and allowing the map to take full height of widget space
Installation Groups: Rows with installations from installations table are now clickable.
Installation Groups: Alarm notifications are now managed on both installation level as well as on installation group level.
The toggle within an Installation always shows the current setting for the user for that Installation.
Within an installation group, the toggle controls the settings for all Installations within that group to which the user does not have direct access.
2021-12-31
2021-12-29
2021-12-24
2021-12-23
2021-12-14
2021-12-13
Dashboard: add Frequency to the details block of the AC Output and Critical Loads tile
Dashboard: add Grid voltage, current, power details per phase
Dashboard: add Generator details.
2021-12-10
2021-12-08
2021-12-07
2021-12-01
2021-11-30
2021-11-29
2021-11-26
2021-11-25
Advanced Page: Ensure that temperature graphs are rendered properly after installation updates (once a minute).
Firmware Update Steps: Instead of typing YES, now users confirm acknowledging the action by ticking a checkbox.
2021-11-24
Venus
OS Large: add menu item and buttons for Node Red, Node Red Dashboard and Signal K.
2021-11-23
2021-11-18
Dashboard: Icons are centered vertically relative to the title
Teams and Groups: Styling properties of page “teams” were applied to other pages to remove inconsistencies.
Login: Removed stay signed asterisk.
Login: Add autofocus for the 2FA field when it appears on the screen.
2021-11-16
2021-11-11
Advanced: Add widget for Battery monitor warnings and alarms.
Advanced: For VE.Bus and Battery monitor warnings and alarms widgets, show on the Y-axis only attributes with data.
2021-11-08
Dashboard: Add minimal and maximal temperature in the last 24 hrs as details for each sensor.
Dashboard: Improve naming for tanks and temperature sensors by using custom name, temperature/tank type, and instance numbers.
Dashboard: Make font sizes and weights more consistent.
2021-11-05
Device list: Added signal strength icons to depict Excellent, Good, Fair to poor, or No signal strength along with the respective value
2021-11-04
2021-11-03
Fixed the dashboard, the installation overview as well as new installation registration not working in countries where google is blocked, such as China:
Advanced: Discontinue state diagram blocks when no data is available.
2021-10-19
2021-10-18
2021-10-11
2021-10-07
2021-10-04
2021-09-28
2021-09-27
2021-09-22
2021-09-21
Fix data points grouped incorrectly in advanced page state widgets
Redirect to the installations overview after deleting or unlinking an installation
Add Battery Consumed Amphours widget
2021-09-20
Add time to the tooltips of the historical data charts.
Improve quick ranges selection and rounding in the historical data part of the dashboard.
Update translations (de, fr, nl, tr, zh)
2021-09-15
2021-09-13
Improve tanks and temperatures overview on the dashboard, grouping tanks per type, sorting groups by name and show temperatures on the dashboard
Advanced: Store the chart plot settings (the selected phase, or the voltage and so forth, for the graph widgets
Advanced: Improve widgets resizing and moving for touch-enabled devices to prevent accidental changes while scrolling
Improve the ‘add installation’ wizard. An optional installation name can now be given for new installations
Improve firmware update, showing realtime progress
Improve precision for historical data when selecting custom ranges
Add a profile setting to display dashboard/widget volumes in US gallons
Add button tooltips in several locations
Fix date range positioning in historical data tooltips
Fix PV Inverter not connected to the multi in the dashboard overview
Fix advanced input state widgets not showing data in some cases
2021-09-08
Add team-level alarm notification subscription toggle: you can now enable alarm notifications for a whole team. Note that this feature will be removed soon. Instead we'll add the enable/disable toggle for installations to the Installations group page. On that page, a user connected to the group will be able to enable/disable alarm notifications for him self. The admin of the group is able to change the enable/disable setting for each user. Also, the admin of the installation group is able to enable/disable alarm notifications for User teams linked to the installation group. If a user is also directly connected to an installation, and disabled notifications there, than that will have priority: he will not receive notifications for that installation. If thats the case, then the toggle switch on the Installations group page will indicate that, for example by turning yellow and having a explaining mouse-over.
Add uptime to gateway on device list
2021-09-06
Improve the positioning of the PV Inverter tile on the installation dashboard
Improve readability of time to go on battery summary widget
Permission changes are now logged for future auditing
Fix synchronized tooltip for temperature and state widgets
2021-08-23
2021-08-19
Improve user experience when selecting custom date ranges
Improve general experience across different browsers
Reduce network usage on installation overview
2021-08-17
2021-08-16
2021-07-05
Add teams and groups to VRM permission system
Add ability to clone the advanced page widget layout to other installations
Updated translations
Fix advanced page showing error after loading widgets for some users
2021-06-30
2021-06-21
Switch advanced page export to xlsx file format when exceeding excel column limit
Add dutch language option
Add explainer video to GX device replacement wizard
New system critical loads graph widget
2021-06-09
Update translations for German, Spanish, French, Dutch and Chineese.
Fix installation overview always having detail mode reset for users with many installations
Reduced realtime broker load by using lower keep alive interval
2021-05-20
2021–05-17
Fix advanced page resetting date range after user changes it if the advanced page opened from the alarms page
Show time remaining for battery block (when charging) on the installation dashboard
Fix a zoom issue for FF block on the installation dashboard
Convert realtime volumetric units to gallons when profile is configured to show gallons
Show zero baseline more clearly on advanced page charts when there are two Y-axis present
Move the reset zoom button into the widget settings panel (gear icon)
Update translations
Changed issuer of mobile authenticator tokens to vrm.victronenergy.com (existing tokens will still work, if you want to update your token then unlink your devices)
2021-05-14
2021-05-10
2021-05-03
2021-04-19
2021-04-10
2021-04-09
2021-03-29
2021-03-21
2021-03-18
2021-03-12
Show more information about connected batteries on installation dashboard
Fix batteries display flickering on installation dashboard
Fix alignment of tanks on installation dashboard
Fix installation dashboard wrongly showing generator block as disconnected in some cases
Fix some inconsistent energy flows on installation dashboard for AC-in
2021-03-11
2021-03-08
2021-03-06
2021-03-04
2021-03-03
Major upgrade of installations overview, including:
Sort installations on alarms by default
Sort down installations that have not been online in several months
Added “detail mode” to installation overview, showing more information about the installations
Added sparkline charts to installation overview, showing data for the last 24 hours (detail mode only)
Improved performance of installation overview for accounts with access to many installations
Prevent user logout during firmware update
Cancel active logins when user changes password
Revoke access tokens after user changes password
2021-03-02
Fix timezone bug in recurring reports
Fix inconsistent behaviour of recurring reports when reporting monthly data over a gap-year
Update wording for warning of double download
2021-03-01
2021-02-28
2021-02-26
Added “Are you sure?” checks before performing firmware updates to VE.Bus
Support uploading VFF files for firmware updates
Show device connection for VE.Bus devices in firmware updater
2021-02-16
2021-02-15
2021-02-11
2021-02-10
Show ‘Add installation’ screen after logging in through VictronConnect when trying to access an installation you don’t have access to
Fix issue with selecting photos on iPhone when changing an installation avatar
2021-02-08
Add “Clear open alarm” to manually clear alarms on installations
Add installation setting to disable realtime data in VRM
Update advanced page status, now similar to that of installation dashboard
Add map view to weather block on the installation dashboard if there is GPS data
Hide installation dashboard charts which don’t contain any data
Fix self-updating installation dashboard charts
Fix some cases where installation dashboard shows incorrect flows
Enable historical data piechart tooltips for mobile phones
Fix DC power block on installation dashboard cutting off peaks in some cases
Add new MPPT RS graph widgets for voltage and current
2021-02-05
2021-01-25
2021-01-18
2021-01-14
On installation overview, show setting values when they are more recent data-wise
Fix bug in timezone conversion
2021-01-13
2021-01-05
2021-01-02
2020-12-24
2020-12-10
2020-12-07
2020-12-04
2020-12-03
2020-11-30
2020-10-11
2020-10-02
2020-10-01
2020-09-29
2020-09-28
2020-09-25
2020-09-22
2020-09-21
2020-09-02
2020-08-21
2020-08-17
2020-07-29
2020-07-28
Make installation overview more readable for a lot of installations
Align labels of the state widgets with the graph charts for easier analysis
Improve login screen autocompletion and usability
2020-07-27
2020-07-14
2020-07-13
Show 'no data' when summary widgets don't have any data for the given installation
Add charger AC power and current widgets
Add digital inputs to the device list
Add digital input state widget
2020-07-09
2020-07-07
2020-07-01
2020-06-11
Add device custom names to alarm log
Add device icons for fuel cells
Add device icons for GlobalLink devices
Add fuel cell widgets
Add ESS battery life state widget
2020-05-12
2020-05-05
2020-04-27
2020-04-08
2020-03-18
2020-03-05
2020-03-02
2020-02-13
2020-01-31
2020-01-29
2020-01-17
2020-01-15
2020-01-13
2020-01-07
2019-12-20
Removed unnecessary attributes from the alarm rules wizard
Added a Signal RSSI widget for LTE-M devices
Fixed the axis configuration of the BMS graph widget
2019-12-13
2019-12-12
2019-12-11
Change axis switching logic on the dashboard, so that the axis always correctly reflect the shown data
Add altitude to GPS widgets
Hide speed from dashboard location block if it is not available
2019-12-10
2019-11-28
2019-11-21
2019-11-19
2019-11-14
2019-11-11
2019-11-06
2019-10-30
2019-10-25
2019-10-23
2019-09-18
2019-09-16
2019-09-02
Fix small gaps in the 'Off' state of the MPPT state widget
New widget for meteorological sensors on the advanced page
Show remote support IP next to the remote support port when available
Show gateway serial number on the device list if available
2019-08-30
2019-08-27
2019-08-16
Fix an issue where the time of the datepicker would change after a page reload
Added the instance number to the device list entries, making it easier to distinguish devices of the same type
2019-08-14
2019-08-13
2019-08-09
2019-08-05
2019-08-02
2019-07-29
2019-07-08
2019-07-03
2019-07-02
2019-07-01
2019-06-27
2019-06-18
2019-06-17
Change margins and padding on the advanced page
Advanced page drag & drop is now support on more screen resolutions
Added the VE.Bus hardware configuration on the system overview page
2019-06-14
2019-06-12
2019-06-11
2019-06-06
2019-06-05
2019-06-04
Show remote support port on device list page
New advanced page: you can now put widgets next to each other and resize graphs on the advanced page
Improved datepicker: It's now easier to select common ranges for the datepicker
2019-06-03
2019-05-22
2019-05-20
2019-05-17
It is now possible to see the current alarm of an installation from the installation page
Only non automatic tags are shown on each installation page, saving some space on small screens
2019-05-16
Fixed an issue where the down arrow of the remote console was not accessible on some screen resolutions
Fixed an issue where the 'No data found' text was not visible for some charts
Auto-reloading of the dashboard chart works again
2019-05-14
2019-05-02
2019-05-01
2019-04-30
2019-04-25
2019-04-19
2019-04-15
2019-04-12
New inverter widgets: State, Output voltage and current
Added support for multiple services in Remote VEConfigure
Added battery charge voltage to BMS charge and discharge limits widget
Added phase rotation to VE Bus warnings and alarms widget (if applicable)
Added high DC ripple to VE Bus warnings and alarms widget (if applicable)
Improved GPS widgets: added current location, it shows a warning if the data is old, and added a terrain mode switch to the map
Added generator state widget
Added generator state to dashboard generator block
Added battery temperature widget
Added battery temperature to VE Bus summary widget
2019-03-29
2019-03-28
2019-03-21
2019-02-15
2019-01-29
Added Octo GX to add installation screen
Device list now shows the proper icon for each type of gateway
Fixed sorting on the installation overview page
Added battery current to the battery block on the dashboard
2019-01-26
2019-01-21
2018-12-12
2018-12-10
2018-11-22
Added Russian as a language (and improved other translations)
Added device id to VE.Bus data on the device list page
You can now add VRM to your home screen on your Android phone (PWA)
2018-10-26
Show more data points on advanced charts when zooming in
Renamed username to e-mail
Allow firmware updates for devices without any firmware installed
2018-10-19
2018-10-17
2018-10-16
2018-09-28
2018-09-27
2018-09-11
2018-09-06
Added more data points per pixel on advanced graphs, makes it easier to spot peaks / anomalies
Fixed an issue where in some cases state widgets where not updating properly
Improved UX on installation tag page, with autocomplete as well
2018-09-05
2018-09-04
2018-08-29
2018-08-24
Fixed issue for VE.Direct LoRaWAN modules: Battery State “charging” was reported as “discharging”.
Fixed issue for VE.Direct LoRaWAN modules: Battery Time-To-Go was reported in minutes instead of hours.
2018-08-14
Changed and adjusted graphs visual aspects: labels, transitions, z-indexes, etc.
Synchronised and aligned the graphs from the Advanced page.
Added a vertical synchronised bar on mouse/touch hover for the time graphs from the Advanced page.
2018-08-03
2018-07-27
2018-07-16
2018-05-23
Increased stats
API endpoint limits for intervals 15mins and hours. This used to be a maximum date range of 2 days, now it is increased to a maximum of 31 days.
Updated
API docs to explain how to use access tokens
2018-05-22
2018-05-16
2018-04-19
2018-02-27
2018-02-13
Added battery/bms parameters 'High charge current alarm', 'High discharge current alarm', 'Cell Imbalance alarm', 'Internal error alarm' to the list of parameters being watched over by the Automatic alarm monitor. This fixes alarms like this not being shown in the Alarm log on VRM. Note that these alarms only show for devices that support these types of alarms. In this case that will be (some) lithium batteries such as BYD.
2017-12-18
New widget added: Graph - Solar Charger Loadoutput Current
Displaying time to go only when necessary and accurate
Fixed a few Spanish and Portuguese translation terms
2017-11-13
2017-10-19
2017-10-04
2017-10-03
2017-09-15
2017-09-12
2017-09-07
Show stats of uploaded CCGX databases, so you know what happened
Only show total of PV Inverter Status if there are multiple phases
Only offer battery history widget if there is a BMV or Lynx shunt available
Optimized some InfluxDB queries
2017-08-03
2017-08-02
Added more values to device list for PV inverter and VE.Bus
Improved share a site model, works better on your phone now
2017-07-25
Instead of showing N/A on dashboard when a value is not available, we now fallback to other values if possible
Made some adjustments to the legend of live feed graph, to correctly reflect what is plotted
Hide the graph selector on the dashboard when only one graph is available
2017-07-20
Altered the user overview of in installation so it works properly on your mobile phone
Made adjustments to installation overview, it now better reflects new gateway types and only shows data when it's there
State widgets, hours of AC calculation and GPS tracks download are now also loaded from Influx, reducing load times
Added a summary widget for Tanks on the advanced page
2017-07-12
2017-06-28
Improved readability of VRM
API docs
2017-06-27
2017-06-19
2017-06-13
2017-06-07
2017-05-31
2017-05-16
2017-04-21
2017-04-13
2017-04-06
2017-03-31
Added Remote on
LAN IP to device list
2017-03-29
2017-03-28
2017-02-27
2017-02-15
Improved the speed of XLSX data downloads
Removed the total from the live feed graph, it did not make sense there (it is still there on the consumption and solar graphs)
2017-02-01
2017-01-25
2017-01-24
2017-01-23
Fixed an issue where tooltips of the advanced tab graphs did not respect the installation timezone
Improvements to registration flow: autologin after e-mail has been verified
Improvements to reset password flow: autologin after password has been reset and prefill form with e-mailadress
2017-01-19
Zoom state on advanced tab is now reset when a date range is selected that lies outside the zoom state range
Clicking on an installation name in the menu now directly leads to the installation dashboard, saves you a click when switching installations
2017-01-18
Fixed an issue where the tags
API endpoint could return an empty document
2017-01-13
2017-01-12
2017-01-11
2017-01-10
Fixed an issue that caused some installations to disappear from Victron World
Fixed an issue where the current date was unselectable on the advanced tab
Improved the scaling of battery voltage graphs
Fix photo size on user uploaded photos
Added totals to the tooltips of the graphs on the dashboard page
Only show 'no data found' if we are not loading
Allow up to 64MB downloads for CCGX data files. Since these can also be zipped, 64MB is really lots of data (more than a year in most cases)
2017-01-09
2017-01-06
2017-01-04
2017-01-03
2017-12-23
2016-12-22
Added genset data to AC source column on installation overview
Added multi phase support VE.BUS Warnings and alarms widget
Added last hour option to advanced tab date dropdown (with auto data reload every minute)
Fixed an issue that resulted in an error (Failed to process file) while uploading a CCGX file
2016-12-20
2016 Nov. - New VRM API
2016-09-09
2016-06-07
2016-06-06
2016-06-03
2016-05-11
2016-04-12
2016-03-31
2016-03-11
2016-03-07
2016-02-01
2016-01-15
There is a new link on the top menu,
Upload CCGX file. Use it to upload .sqlite files which are stored by the CCGX on a SDcard or USB stick. This fixes the issue where, even when configured to log to SDcard or USB-stick, it was necessary to first, only once, connect the CCGX to the internet. With the new change, you'll be able to add the site to your account a few minutes after uploading your data file. More information in the
CCGX manual, chapter 2.2.2.
2015-12-08
2015-12-04
2015-12-02
2015-11-30
2015-11-17
2015-10-30
Significant performance improvement to data export; initial testing shows downloading a CSV file now takes up to ten times less time.
Fixed issues with the total line summing in graphs with overlapping gaps.
2015-10-26
2015-10-23
Added a cumulative total line to graphs which contain summable data, which can be toggled using the label in the header of the graph.
Changed the layout of the PV Inverter widget to improve readability.
Fixed an issue with the VE.Bus State graph displaying non-existing data points when a gap in the data logging was detected.
Show absolute times instead of relative times when the last update is more than six hours ago.
2015-10-20
2015-10-19
2015-10-12
2015-09-22
Combined SOC and the TTG on the Battery status widget on the advanced tab: it fits in one widget so no longer scrolls
Entering Company name is no longer required for new users during registration
Remember filled out email on opening forgot password form
2015-09-11
Fixed zooming out on any graph, not just the graph that the zoom was performed on.
Only zoom on the X-axis, making sure data is always in view on other graphs.
Only show one phase for frequency since they're all the same.
Fixed “today” button misbehaving when the page was open overnight.
2015-09-08
2015-09-03
